Which is better K20A or K20Z???????
Old Jun 15, 2007 | 03:41 PM
jdmdc5integra's Avatar
Default Which is better K20A or K20Z???????
Thinking about doing a motor swap from K20a2 but don't know which engine is better and why? Any suggestions would help........
Old Jun 15, 2007 | 03:44 PM
risktypeS's Avatar
Default Re: Which is better K20A or K20Z??????? (jdmdc5integra)
it all depends on what you're trying to accomplish and where you're going. what is your goal is basicly what it boils down to. Kind of need more explanation here.
Old Jun 15, 2007 | 03:51 PM
Default Re: Which is better K20A or K20Z??????? (risktypeS)
I want to go turbo!
Old Jun 15, 2007 | 04:39 PM
risktypeS's Avatar
and you have i'm guessing a k20a2?
Old Jun 15, 2007 | 05:37 PM
yes...
Old Jun 15, 2007 | 06:30 PM
risktypeS's Avatar
why would you want to spend a lot more money on a k20z1 when it's roughly the same as a k20a2 just a little more better parts then A2. K20A it is a powerful motor but then again.. why would you want to spend a lot of money just to swap to a k20A just for an extra what 20hp? You have a k20a2 and they make plenty of power and if you go turbo (get a rightfully sized turbo) you can make a good amount of power stock. What are your plans with turbo? Staying stock, fully built?
*edit* dude i can't help but to keep looking over at that cartoon avatar, even tho it's a cartoon it's kinda funny.
Modified by risktypeS at 8:08 PM 6/15/2007
Old Jun 15, 2007 | 07:37 PM
dc5RickK20's Avatar
if your gonna go boost it doesent really matter what motor you have if anything the k20a is the worst for boost because of the higher compression and smaller crank pulley. to sum it all up you dont need a different motor to make power on boost
Old Jun 15, 2007 | 07:42 PM
risktypeS's Avatar
Default Re: Which is better K20A or K20Z??????? (dc5RickK20)
^^^ agreed
Old Jun 15, 2007 | 09:52 PM
Aco512's Avatar
you stock motor is just fine for boosting
with the cost of the manual labor, it can go into the turbo-kit
Old Jun 16, 2007 | 10:43 AM
Default Re: (Aco512)
I'm staying stock I don't think I'm gonna go all out. Well thank you guys for answering my question that is all I needed just some expert advice!!!
Old Jun 17, 2007 | 03:30 PM
20CiviC02Si's Avatar
Default Re: (jdmdc5integra)
Agreed! If you are going for boost. Your best bet will be to purchase a set of lower compression pistons for you K20a2. The K20a2 is no different from the K20a except the k20a has higher compression. Also if you were to get the K20z1 you would have issues with getting KPRO to work properly. They have not worked out all the bugs for the newer Si and Type S's.
Old Jun 17, 2007 | 04:39 PM
dc5RickK20's Avatar
Default Re: (20CiviC02Si)
well all you would need is a different wire harness and an 02-04 ECU to connect k-pro to an 05 type s i have an 02 type s with a k20z1 with k-pro running just fine and i didnt need to change the harness because its an 02 but the only reason i went with the k20z1 is because i blew my motor and got a killer deal on the k20z1
EduardoDC5
Jun 24, 2007 05:26 PM
wound tight
30
May 22, 2007 05:19 PM
92hondaGSRchick
26
Jan 13, 2005 04:30 PM
HamiltonRex
Apr 26, 2004 06:15 PM
