6x9" in front doors???
Old Jun 15, 2007 | 01:37 PM
mark2583's Avatar
Default 6x9" in front doors???
has anyone ever been successful in fitting 6x9" speakers in the front doors of a 5th gen 4 door
Old Jun 15, 2007 | 03:32 PM
JDM_DC4_Fanatic's Avatar
Default Re: 6x9" in front doors??? (mark2583)
why would you want 6x9's in the doors? Oval speakers arent acoustically as good as round speakers. get oversized 6.5" component speakers in the front doors, and mount the tweeters up high and you wont be dissapointed. Clear high's and thunderous mid bass, almost wont need to run a sub.....almost :
Old Jun 15, 2007 | 04:51 PM
droppedakord09's Avatar
acually i have a set of focal component speakers in front and a set of focal 6x9s in that back hooked to an amp and i think it sounds better then if i had sub?? and about fitting 6x9s in the front.... i had trouble fitting 6.5 inch ones in there cause its sooo close to the window when its down
Old Jun 16, 2007 | 02:01 AM
philadd's Avatar
Default Re: (droppedakord09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedakord09 &raquo;</TD></TR><TR><TD CLASS="quote">i had trouble fitting 6.5 inch ones in there cause its sooo close to the window when its down</TD></TR></TABLE>
You needed to either, 1) buy a speaker with a shallow mounting depth, 2) buy spacers, or 3) make spacers.
But JDM_DC4_Fanatic is correct, round speakers produce better sound quality than oval speakers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedakord09 &raquo;</TD></TR><TR><TD CLASS="quote">acually i have a set of focal component speakers in front and a set of focal 6x9s in that back hooked to an amp and i think it sounds better then if i had sub??</TD></TR></TABLE>
If that's the case, you didn't have everything adjusted right, you bought the wrong setup for your tastes, or you bought poor quality speakers and/or amp.
Old Jun 16, 2007 | 03:18 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 6x9" in front doors??? (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">why would you want 6x9's in the doors? Oval speakers arent acoustically as good as round speakers. get oversized 6.5" component speakers in the front doors, and mount the tweeters up high and you wont be dissapointed. Clear high's and thunderous mid bass, almost wont need to run a sub.....almost : </TD></TR></TABLE>
Not true. Have you tried ma audio 5x7-6x8 componet set or the kicker version? They perform very welll and sound really good. And they give out great midbass while they are playing. I used them in a mustang and was very impressed with them. So have alot of people.
Old Jun 16, 2007 | 05:39 PM
Default Re: 6x9" in front doors??? (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">
Not true. Have you tried ma audio 5x7-6x8 componet set or the kicker version? They perform very welll and sound really good. And they give out great midbass while they are playing. I used them in a mustang and was very impressed with them. So have alot of people.</TD></TR></TABLE>
Sorry, I should of said 'typically' round speakers sound better then oval speakers.
Old Jun 17, 2007 | 08:12 AM
jz98ctr's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">You needed to either, 1) buy a speaker with a shallow mounting depth, 2) buy spacers, or 3) make spacers.</TD></TR></TABLE>
spacers would help some but the factory grilles would still be covering almost half of the oblong speakers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">But JDM_DC4_Fanatic is correct, round speakers produce better sound quality than oval speakers.</TD></TR></TABLE>
round speakers are just better sounding for one reason...they are round! here's a little analogy...have you ever seen a round above-ground pool???
have you ever seen an oval above-ground pool??? the round pool requires no external bracing due to it's round shape. the oval pool requires external bracing because it has flat/close to flat sides. the weight of the water exerting against the inside edges of the round pool is evenly distributed along the walls requiring no bracing. the flat sides of the oval pool require the bracing because the water is pushing against the flat sides with more pressure than its round ends. round speakers are just plain sound more linear in their performance. ovals tend to get a little overly heavy on the midbass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">If that's the case, you didn't have everything adjusted right, you bought the wrong setup for your tastes, or you bought poor quality speakers and/or amp.</TD></TR></TABLE>
since when have focals become poor quality speakers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedakord09 &raquo;</TD></TR><TR><TD CLASS="quote">acually i have a set of focal component speakers in front and a set of focal 6x9s in that back hooked to an amp and i think it sounds better then if i had sub?? and about fitting 6x9s in the front.... i had trouble fitting 6.5 inch ones in there cause its sooo close to the window when its down</TD></TR></TABLE>
a properly setup and tuned system in the right car can still sound great with no sub...it's been done tons of times before. obviously there is that missing thunder but you can still get great response.
Modified by jz98ctr at 7:33 PM 6/17/2007
Old Jun 17, 2007 | 12:13 PM
8520's Avatar
Default Re: Re: (jz98ctr)
If you want bass, add a sub. If you want clarity, get better speakers and whatever you need to run them (ie better hu, amp, etc)
Old Jun 17, 2007 | 07:12 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">since when have focals become poor quality speakers?</TD></TR></TABLE>
I never said the brand was poor quality. I was referring more to the possibility of used speakers, etc.
Old Jun 17, 2007 | 07:48 PM
incubus's Avatar
Sorry, I should of said 'typically' round speakers sound better then oval speakers.</TD></TR></TABLE>
no, what you said was correct dont alter your statement. sure 6.5s dont have as much bass response as thier 6x8 or 6x9 component, but if someone is serious about car audio it doesnt matter. oblong speakers are a byproduct of compromises made by the acoustically limited OEM car audio designers.
1. notice how most high end car audio companies dont produce oblong spkrs in thier higher lines, it would be a contradiction
2. notice that home audio doesnt use oblong spkrs because space isnt an issue.
MA audio is a 3rd rate car audio company and kicker is good at best. at least kicker has a high line, SS, which are only offered in 6.5" and 5.25
If you want good bass from your door spkrs buy some MB quarts (reference or higher) a clean and powerful amp to drive them, and dynamat your door really good.
Old Jun 18, 2007 | 01:08 AM
8520's Avatar
Default Re: 6x9" in front doors??? (incubus)
Mb quarts are far too bright for most people; that is, unless you put a layer or two of carpet over the tweeter.
Old Jun 18, 2007 | 02:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">
If you want good bass from your door spkrs buy some MB quarts (reference or higher) a clean and powerful amp to drive them, and dynamat your door really good.</TD></TR></TABLE>
No he was right i changng re-wording his post. Hell jl audio was a third rate car company as you called ma. I remember when no one wanted their product or subs when that what they had to offer. Look at them now. If alpine or some other high end company started a run of 6x8 componets. Everybody else would jump right in. Hell look at the shallow-mount sub. Everybody makes them now.
Old Jun 18, 2007 | 04:05 PM
incubus's Avatar
Default Re: 6x9" in front doors??? (misanthropist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">Mb quarts are far too bright for most people; that is, unless you put a layer or two of carpet over the tweeter.</TD></TR></TABLE>
that is of course completely subjective, they do come with jumpers and I have mine set at -6db and they sound fine, and i dont even like highs. besides when have you been to a concert and not heard too much highs mixed into the music, the guys who usually mix live music are most of the times tone deaf of highs. Fact is live music is almost always harsh.
Old Jun 18, 2007 | 11:36 PM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">that is of course completely subjective, they do come with jumpers and I have mine set at -6db and they sound fine, and i dont even like highs. besides when have you been to a concert and not heard too much highs mixed into the music, the guys who usually mix live music are most of the times tone deaf of highs. Fact is live music is almost always harsh.</TD></TR></TABLE>
Fu[/i]ck subjective. I'm right about everything! !!
With most concerts I find it's just too much of everything, and besides how often do you listen to "live" music for sound quality? Even when mixed & recorded separately it's usually not as good as a studio recorded album.
Old Jun 19, 2007 | 06:09 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">With most concerts I find it's just too much of everything, and besides how often do you listen to "live" music for sound quality? Even when mixed & recorded separately it's usually not as good as a studio recorded album. </TD></TR></TABLE>
i'd have to agree...most live concerts are definitely not about the SQ...but they are all about the dynamic headroom.
madblkscientist
Audio / Security / Video
20
Aug 25, 2009 12:07 PM
GetCaughtDead
Honda S2000
10
Nov 16, 2006 04:34 AM
T-RO
Aug 10, 2005 09:06 AM
Unjockable
18
Jul 5, 2004 10:24 AM
mstewar
Jan 3, 2004 09:07 AM
