h2b?
iv been doin research on the h2b, i see that there are a lot of little things that they suggest you do like removing the balance shaft, the alt relocation, the shaving of the crank pully, anyways i was wonderin if all these things are nessesary, i mean cant u just bash the frame in....btw i want to do the swap on my 96 hatch....so can anybody explain whatsabsolutely nessesary to do, i rather bash my frame than having to buy all types of kits to relocate alts and to remove shafts n stuff if u guys know what i mean, am on a tight bugget
i just did the swap in my 98 hatch. i shaved the crank pulley and i still had to bash the frame rail. also im using an alt. relocator kit. if you dont you have to bash the frame rail a lot for the stock to work. i dont even think i could use the stock on mine though.
Check out the Evolution Industries kit, which pretty much eliminates frame rail and hood clearance issues. If you have any questions just PM me and I can help answer them for you.
Hondacivic90ed
Aug 11, 2012 05:41 PM
