All motor GSR build. Stock vs Aftermarket Retainers, Stock vs Bronze Valveguides?
Old Jun 15, 2007 | 10:46 AM
OMG THE GOGGLES's Avatar
Default All motor GSR build. Stock vs Aftermarket Retainers, Stock vs Bronze Valveguides?
GSR build from the top down. All aftermarket head components from supertech, but hear bad bad things about titanium retainers and want something a wee bit stronger. What do you suggest? I know supertech came out with new retainers, and I beleive crower has stainless ones too. Voice your opinion
Also, running bronze valveguides vs stock oem's? Any benefit or dis-benefit in a motor that wont be pushing over 240whp?
Old Jun 15, 2007 | 11:21 AM
sauceja's Avatar
Default Re: All motor GSR build. Stock vs Aftermarket Retainers, Stock vs Bronze Valveguides? (OMG THE GOGG
I wanted the supertech aluminum retainers but they didn't have any when I bought mine so I got ti retainers.
You shouldn't have any problems.
make sure you get the new guides reamed.
I have heard more good things with supertech than bad that is why I went with them.
Old Jun 15, 2007 | 10:01 PM
Yea, how about the bronze valve guides, useless? I am most likely going to stick with OEM honda
Old Jun 15, 2007 | 10:19 PM
ekb16's Avatar
i think OEM valve guides should be fine...for me im going with Ferrea EX and IN valves guides for my K series, kinda pricey tho..as for retainers, you should talk to Jeff at Import Builders about his valve train components he sells, they are really good
http://www.importbuilders.com/
Old Jun 16, 2007 | 05:27 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (ekb16)
bronze valve guides and Crower chromoly retainers FTW. I had bad feeling about the titanium ones also and have only heard good things about the chromoly ones.
Old Jun 16, 2007 | 10:28 AM
sauceja's Avatar
Default Re: (attentionwhore)
I liked the chromoly ones as well but couldn't find the ones I really wanted. So I went with titanium.
I would go with bronze valve guides in a second with no hesitation. OEM's are never a bad move either though. Depends if you want oem reliability or more of a race motor.
Either guides you get will depend on who installs them and if done correctly and measured/reamed after.
Old Jun 16, 2007 | 12:08 PM
Default Re: (sauceja)
The guy doing my machine work is very reliable, so I will be going with OEM as its not a race bred motor. Most likely going with the Crower chromoly ones also. Anyone have the exact part number for them that they used? Thank you in advance, and thank you everyone for replies
Old Jun 16, 2007 | 05:49 PM
Default Re: (OMG THE GOGGLES)
87093S-16
Old Jun 16, 2007 | 10:45 PM
dude_123's Avatar
Anyone knows the measurement of the 2nd dia. of these crower chromoly retainers?
Old Jun 17, 2007 | 01:30 PM
LPoke's Avatar
i was running b20vtec with gsr head... then my valve guide cracked off... =[
Old Jun 17, 2007 | 06:13 PM
methos713's Avatar
Default Re: (LPoke)
what is the benefit of using bronze valveguides?
Old Jun 18, 2007 | 02:18 AM
neo_'s Avatar
Default Re: (methos713)
Running Ferrea Titanium retainers (with Ferrea Springs) for 20,000 miles with no problems. Car was even daily driven for 10,000 of those miles.
Old Jun 18, 2007 | 06:20 AM
92redhatch's Avatar
i have REV ss valves, dual springs and titanium retainers. i was told that the factory honda valve guides over time go bad with SS valves. Im not a 100% but i have bronze guides on my b16 head. and i have zero problems.
Old Jun 19, 2007 | 01:05 PM
methos713's Avatar
Default Re: (92redhatch)
are bronze valveguides good to use on a head that will be boosted?
Old Jun 20, 2007 | 05:12 AM
92redhatch's Avatar
i dont see y not.
sh!ft
Mar 9, 2012 01:56 AM
airmaxbri
Feb 21, 2010 08:47 PM
ruffrhyder
Jul 14, 2008 04:48 PM
neofreak
Jul 1, 2007 12:04 PM
mymeatb18"
11
May 6, 2006 10:51 AM
