oil temp and oil pressure gauge issue
Old Jun 15, 2007 | 09:38 AM
patrick4588's Avatar
Default oil temp and oil pressure gauge issue
the gauges work fine until i got WOT. when i do that, they both go to 0. im using a blox oil filter adapter and both gauges are stewart warner. i also had some cheap gauges hooked up on the oil adapter and they did this too. i assumed it was the cheap gauges so i bought the nice stewart warner ones. and they do it too. this is not normal is it?
Old Jun 15, 2007 | 08:01 PM
Sam92Teg's Avatar
Default Re: oil temp and oil pressure gauge issue (patrick4588)
I have heard of issues if the sending units aren't grounded properly.
Old Jun 15, 2007 | 10:38 PM
hmmm. well its fine under all conditions except WOT. that could be it i guess. the sandwhich adapter isnt touching any metal since it uses a rubber gasket to seal it.
accord_raffi
Nov 6, 2008 04:26 AM
twiztid00002
Feb 3, 2008 06:27 PM
CivicMike
May 26, 2005 09:34 AM
onyx00
May 14, 2003 06:22 AM
sslude
Feb 25, 2003 08:31 PM
