Suspension & Brakes Theory, alignment, spring rates....
95 Hatch Cx/95 teg shock swap?
Old Jun 15, 2007 | 07:39 AM
HondaBurger's Avatar
Default 95 Hatch Cx/95 teg shock swap?
My whole entire shock/strut assembly is blown on my 95 cx hatch, so i will need to replace front and rear. Are there oem parts I could use off of other cars that i could find at a junkyard? Like a 95 teg or something?
Old Jun 15, 2007 | 01:31 PM
ventturei27's Avatar
yes u can, the only issue from the integra is that it might raise your car a bit, the struts on a 94-01 integra are meant for a heavier car when put on a 5th gen hatch , theat car gets a bit taller, you can usually get a decent set of shosck/wprings for around 300 for everything, you will be lowered and everything will be nice and stiff
Old Jun 15, 2007 | 02:05 PM
Default Re: (ventturei27)
thanks for the help
HondaBurger
Welding / Fabrication
Jun 13, 2007 01:42 PM
