Should I remove the idler pulley on my k20?
OK...so i remember reading sumwhere that u can remove the idler pulley by using a different belt (civic's K20) or sumthing like that..but my question is...Should I do it?, will it cause it to idle hard? or not at all...cuz i still plan to drive it on the weekends still.........Jus want to know if its still streetable after taking that off.
Modified by richboi at 6:31 AM 6/15/2007
BRAH! check this out...http://www.k20a.org/forum/showpost.p...60&postcount=7
i think you are thinking of the EP3 idler pulley. Since the EP3 has electronic steering, people use the idler pulley from that when they aren't going to use power steering
yea.. thats where i saw it...but still...i wanted to know if that mod leaves my car streetable...jus curious on how bad the idle will be..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">yea.. thats where i saw it...but still...i wanted to know if that mod leaves my car streetable...jus curious on how bad the idle will be..</TD></TR></TABLE>
It will be fine, assuming EP3s idle fine
ktwanky
Jan 19, 2007 09:51 PM
TrueZen
May 2, 2005 03:20 PM
lbirllain
Aug 19, 2004 04:20 PM
