Add a cigarette lighter plug...
Old Jun 14, 2007 | 10:48 PM
JKingCivicSi's Avatar
Default Add a cigarette lighter plug...
Ok, question for you electric gurus. I while ago I spliced in another cigarette lighter plug. i did that just because I didnt like seeing my phone charger in the front. The second one is hidden behind the dash. The two plugs are connected in parallel. Up until now I have only used one at a time. My question is is it safe to use them both? That would double the current passing through the power wire. Would that overload anything or blow a fuse? Thanks for any input.
Old Jun 15, 2007 | 05:32 AM
Wes V's Avatar
Default Re: Add a cigarette lighter plug... (JKingCivicSi)
If you are talking about using two cell phone chargers at once; you should have no problem.
If you are talking about one cell phone and also the lighter; then that may be pushing it.
Just unplug the cell phone when you need the lighter.
Wes
Old Jun 15, 2007 | 07:39 AM
Default Re: Add a cigarette lighter plug... (Wes V)
Hmm. so it also depends on what I plug in. Thanks for the info.
Old Jun 15, 2007 | 08:01 AM
Wes V's Avatar
It's all a matter of how much current you are drawing.
The lighter draws a lot!!! That's why the wire going to it is so large.
Things like a cell phone charger or i-pod power is nothing compared to it.
Wes
Old Jun 15, 2007 | 03:59 PM
95gainfla's Avatar
correct, the phone charger slowly charges, on a low amperage charge, while the lighter is very low resistance to get it hot quickly.
tnxx
Welding / Fabrication
33
Apr 17, 2012 03:10 AM
EF_RICE
Oct 20, 2007 07:37 AM
ekay. jay
Apr 23, 2006 06:13 PM
scdarksol
Nov 30, 2003 09:08 PM
