how much is a hydrolocked b18c worth?
i have a b18c type R motor that has been hydrolocked...
the motor and transmission has roughly 70k miles.
has..
skunk2 stage2 cams
titanium valve springs/retainers..
i took the motor out of the car and sold the shell...
Question is how much is this motor worth? part it out or sell as is?
thanks for any help...
has..
skunk2 stage2 cams
well it depends on the head. if you bent valves and all that in the head it has to be rebuilt so it isnt worth a whole lot. same with the rods...if they got bent from the compression change from the water ther arent worth anything either. I guess all you can do it take stuff apart and see how bad it is. for the long block i wouldnt say more than $700 for what could be the worst with the head and block. good for a hi comp NA rebuild tho.
