01 GSR Dash Help
I have a 01 GSR and i was driving the other night and the dash lights went out. Thought i twisted them off or my headlights where off, but it wasnt that. So the next day i took out the fuse and it was blown so i put the spare fuse in and i still had nothing, took the spare out and it was blown. The blinker lights on the dash work though. So if any one here knows what it is that would be great. Also if anyone knows how to take off the dash that would be great thanks.
copied from integr97 from team-integra...
Dashboard Removal/Installation
Heres a step-by-step writeup on it's removal.
Instrument Panel, Dashboard Lower Cover, Knee Bolster removal:
1. Lower the steering column.
2. Remove the 2 screws holding the Instrument Panel (plastic around the gauges).
3. Remove the Coin Pocket.
4. Remove the 2 screws and 2 clips from the Lower Dashboard Cover. (plastic piece under the steering column)
5. Remove the Knee Bolster (metal plate behind the Lower Dashboard Cover)
Stereo Radio/Cassette, Heater Control Panel removal:
1. First remove the Front & Rear Center Console.
2. Loosen the 2 10mm bolts behind the radio, then pull it straight out. Be sure to remove the wires to the radio and the antenna lead wire also.
3. Carefully pry the Hazard Warning switch and Rear Window Defogger switches out of the heater control panel, and disconnect their connectors.
4. Remove the 2 screws from the Heater Control Panel, and behind there are two clips to remove (wire harness clip & connector clip)
5. Disconnect the air mix control cable from the heater control unit.
6. Pull the heater control panel out, then disconnect it's connectors.
Drivers Side Air Vent removal:
1. Pry the moonroof switch out of the side air vent, then disconnect it's connector.
2. Then remove the screw next to the side air vent, then remove it. (also held by 4 clips)
Passenger Air Vent removal:
1. Pry out the vent from the bottom (3 clips holding this in place)
Clock Removal:
1. Carefully pry the clock out from the left edge, then pull it out. Disconnect its connector.
Glove Box Removal:
1. Open the Glove Box.
2. Remove the screw form the damper, then remove the damper itself from the glove box.
3. Remove the 2 bolts from underneath the glove box, then remove the glove box.
4. Remove the damper (1 nut)
5. Remove the Glove Box striker latch (2 screws)
Dashboard Replacement:
1. lower the steering column by removing the 2 nuts (located near the steering height adjuster)
2. Remove the 4 nuts from under the Passenger Airbag bracket.
3. Disconnet the 4 connectors from the dashbaord which plug directly to the under-dash fuse/relay box.
4. Remove the access panels from both side of the dashboard (in between the door and dashboard, which are held in by clips)
5. Remove the 6 dashboard bolts, then lift and remove the dashboard.
(FINAL BOLT LOCATIONS)
2 on each side of the dashboard, 1 where the clock was, and 1 underneath where the radio was. There should be a total of 6, and they all look the same.
Clock Removal:
Glove Box Removal:
Mar 31, 2002 08:38 PM
