Surging idle on 96 gsr in ek
Old Jun 14, 2007 | 06:52 PM
dashskier540's Avatar
Default Surging idle on 96 gsr in ek
I'll make this short and sweet cause I have checked soooo many forums Heres the setup:
96 gsr in 98 ek
-motor has 100k on it and that I know of it hasnt had a valve adjustment
-obd2 to obd1 conversion done by rywire for all the wiring.
-p06 chipped ecu
-skunk 2 intake manifold
-new timing belt
-new water pump
-new head gasket
For the valve adjustment issue I hear a ticking noise every second or two, Could it be because I need a valve adjustment or my timing belt is too tight?
Idle issues- Once I start the car up it idles at about 1500 rpm, then after about 3-5 minutes of just sitting the idle surges from about 200 to 1000rpm. I've also put in a new IAC. I've looked over so more forums on the fitv, but i thought those werent on the obd2 throttle bodies. I've also checked for vaccum leaks with carb cleaner and came up with nothing. I hope that all you honda gurus find this and help me out.
THANKS!
Old Jun 14, 2007 | 07:07 PM
PhrequenC's Avatar
Default Re: Surging idle on 96 gsr in ek (dashskier540)
i had this same problem on my ex girls 4dr integra. when you drive around it gets fine after awhile right?
Old Jun 15, 2007 | 06:56 AM
Default Re: Surging idle on 96 gsr in ek (PhrequenC)
yup! It's very moody kinda like a gf!
Old Jun 15, 2007 | 10:38 AM
boost4life's Avatar
what about bleeding your coolant most likey or maybe but i doubt it a vacuum leak
Old Jun 15, 2007 | 10:39 AM
boost4life's Avatar
there are a **** load of these threads jus search for some more possable issues
Old Jun 15, 2007 | 12:59 PM
Default Re: (boost4life)
Old Jun 16, 2007 | 04:53 PM
Default Re: (dashskier540)
come on guys please help!!!! I really want to get this thing running the right way!
Old Jun 16, 2007 | 04:54 PM
geebs's Avatar
i had a problem like this with my crx w/ b16a swap.. turned out to be the tps..
just a thought
Old Jun 18, 2007 | 07:24 PM
ST4TUS's Avatar
Default Re: (geebs)
Soak your IACV with brake cleaner.
Old Jun 18, 2007 | 07:33 PM
DFW's Avatar
DFW
Default Re: (ST4TUS)
http://www.ef-honda.com/ben/Badidle.php
overspooled
Sep 2, 2007 07:24 PM
b18c inside
Feb 26, 2006 11:39 AM
Haillie
May 30, 2005 03:20 PM
Slammed Ek9
Apr 7, 2005 03:00 PM
