Another question about how to tell si trans true or false
I know that you can spin the main shaft ten times in first and tell that way but i don't know how to get the transmission into first outside of the car. I did find this though is it true look above the oil fill, there is a stamp that will say PL3/####
PL3/A### = small bearing case - DX/HF/STD
PL3/B000 = large bearing - SI/ZC
PL3/3000/6000/9000 = large bearing - SI/ZC
as for clutches, as long as you have a 90-91 flywheel it will use a 90-91 SI clutch. unless the trans is an '88(21 spline input shaft)
and can i trust it cuz the trans i got says pl3 3000 Thanks and ur quick response is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef »</TD></TR><TR><TD CLASS="quote">
that is correct. as for identification, that looks right also, but you may still do the spin test to be sure.
crazy sohc vtec guy
11
Jul 10, 2008 02:29 PM
1989CivicSi
Nov 6, 2007 05:28 AM
97grnrs
10
Nov 12, 2006 03:45 PM
BrianRacerboy
Sep 30, 2004 12:49 PM
