will a 90-91 teg main harness work in a 90-91 si hatch
i've heard a couple ppl talk about this will it work?
i have NO Idea
but crank windows with crank windows and everything is mostly the same. . . .someone answer this for me
i have a complete 90-91 ls and want to switch it into my si that's fubar'd wiring wise. . . . . .so thanks
i have NO Idea
It will not be a direct plug and play. You will need to do some custom wiring to get it all to work. And you will have to swap the body, dash and engine harness.
well if i strip all the wiring from the hatch and put in all the wiring from the teggy will it work at all? and is the dash a direct drop in?
o and it's into a hatch not a rex not like it matters just clearing it up
Modified by 96pgtmtx at 7:12 PM 6/14/2007
rear 1/2 of the harness (behind the seats) don't matter the indash, and engine harness will be replaced. there will be some fabrications as plugs for things are in different places. heater stuff also have different wiring. so you will have to either swap plugs, extend wires, or use the DA interior and items. A LOT of fabrication. only you can judge if it is worth it.
it's your car, do with what you please.
