Suspension & Brakes Theory, alignment, spring rates....
Coilover Question PLEASE HELP!!
Old Jun 14, 2007 | 04:59 PM
608 Gangsta's Avatar
Default Coilover Question PLEASE HELP!!
Putting Ksports in.. i pre loaded them..
in the rear ive had to raise one side atleast! an inch to match up to the other.. WTF am i doin somin wrong ? could one be more pre-loaded then the other ?
you can totally see my car sits like lop sided ( im not driving it until problem is solved )
now i was thinking about takin them out starting all over..
any suggestions???? any help please anythig would be good
thanks!
Old Jun 14, 2007 | 05:55 PM
Default Re: Coilover Question PLEASE HELP!! (608 Gangsta)
awesome
Old Jun 14, 2007 | 06:34 PM
chrisw85's Avatar
by preloading you mean you snugged up the spring/ring so the spring isn't loose with no weigth on.
and by adjust height you mean you adjusted the 'cup' that the shock body rests in....
if all the spring-ring/perch are the same from the top of where the piston comes out, then yes perhaps all the 'cups' weren't even and thats why you had to adjust one.
Drivers' side usually sits lower even if the springs are even around.
EJ1_CRIS_909
Suspension & Brakes
12
Aug 23, 2011 10:09 AM
wakaranai
Suspension & Brakes
Sep 15, 2008 07:35 PM
rewerbcrx
18
Feb 23, 2007 06:57 AM
Ruthless DC2
Suspension & Brakes
42
Dec 29, 2005 02:27 PM
SuzukaBlueAP2
Jan 31, 2004 10:01 PM
