Transmission refill on manual
Old Jun 14, 2007 | 04:35 PM
teggmann's Avatar
Default Transmission refill on manual
i have a 94 ls with a manual transmission. i need to fill the fluid because of a slow leak. how do i get the fluid in through the side of the fill plug with out it spillin? i dont know if a funnel or a hose or what would work best. anything will help. thanks.
Old Jun 14, 2007 | 06:39 PM
Blahblah718293's Avatar
Default Re: Transmission refill on manual (teggmann)
http://www.team-integra.net/se...D=301
when i did it i took about a foot of plastic tube from an old super soaker and a funnel, stuck the tube in the hole and just measured out 2.3 quarts after i drained it all.
(edit) the tube was just wide enough so i could squeeze the funnel spout in it for a very snug fit, then slowly poured the fluid in.
Old Jun 14, 2007 | 08:08 PM
jonshonda's Avatar
Community Builder
Hose works, and your gonna want to get that fixed soon, cuz if you have to fill it often, your going to hate it!! Best of luck
Old Jun 15, 2007 | 02:09 AM
Default Re: (jonshonda)
and if you run with low or no fluid your gears can seize up and basically explode your tranny.
thats what i think happened to mine wtih the previous owner. i guess they rebuilt it, jb welded the hole shut, and sold it to some stupid newby kid. (me) anyway, the tranny now makes a whole messs of horrible noises so you keep that thing topped off, ya hear?
Old Jun 15, 2007 | 03:07 PM
teggmann's Avatar
Default Re: (Blahblah718293)
do i need to place the tube in the hole directly in the fill plug or in the right side of the fill plug. would a squirt bottle work possibly?!!
Old Jun 15, 2007 | 05:23 PM
sickofitall1113's Avatar
you need to get it so you can empty the tranny fluid in the upright position so it wont just flow back into the bottle. longer the hose the better. hold one hand on the hose into the tranny and squeeze the bottle with the other hand slowly. it takes an annoyingly long time to get it all in there
Old Jun 15, 2007 | 06:13 PM
Default Re: (sickofitall1113)
i just stuck the hose in and it poured in. you only fill it up to the level the fill plug is out. and i think if you used a spray bottle youd get too much air in it. and that would take forever. its not as hard as it sounds, just stick a funnel in the hose, make sure the hose is all downhill to prevent it from backing up, and stick the hose right inside the hole, it doesnt need to go in far.
Old Jun 16, 2007 | 05:26 AM
stumpyf4's Avatar
Pull the fill plug and the speed sensor. Fill the fluid through the speed sensor hole and then the excess fluid will spill out of the fill plug hole.
Roediep
Honda Fit
Feb 13, 2014 11:07 PM
Sprockets
Aug 18, 2007 11:32 AM
amorak
Aug 29, 2006 01:52 PM
Heat
Sep 7, 2005 12:10 AM
