Broken LCA bolts
Old Jun 14, 2007 | 01:40 PM
Jizzmaster Zero's Avatar
(banned)
Default Broken LCA bolts
I had the typical rear lower strut mount bolts snap when I tried to get them out, no biggie. I have the entire driver's side shock/LCA assembly out, but on the passenger side the end bolt on the LCA (wheel end) snapped. Right now it's the only thing holding me up. I used my sawzall to cut through it (partially, need to get more blades this weekend) but now my question is how do I remove the remaining part of the bolt that is threaded into the hub?
Old Jun 14, 2007 | 01:46 PM
rpared01's Avatar
take it to a machine shop and have them take it out or you can do it your self by drilling the bolt out.
Old Jun 14, 2007 | 02:12 PM
(banned)
Default Re: (rpared01)
I can't take my whole car to a machine shop and I'd rather not remove the hub.
Old Jun 14, 2007 | 02:22 PM
Slurp56's Avatar
Default Re: (Jizzmaster Zero)
Drill it out and try not to mess it up. Otherwise, knock off the bung and use a nut and washer with the new bolt. I tack weld the nut/washer to the hub.
Old Jun 14, 2007 | 02:32 PM
rpared01's Avatar
your best bet is to drill it out
Old Jun 14, 2007 | 02:45 PM
(banned)
Thanks for the info guys, I'll see how it goes.
Old Jun 14, 2007 | 03:59 PM
ke98248's Avatar
vise clamps+KROIL/PB BLASTER, that's how I got mine out after using a grinder with a cut-off wheel to chop the rest off.
Old Jun 14, 2007 | 04:54 PM
(banned)
Default Re: (ke98248)
I'm also thinking a pipe wrench may come in handy.
I picked up a couple repair kits from http://www.rockauto.com which includes the bolt/bushing for the lower shock mount, and another bolt+bushing for this damn LCA end bolt.
chillerice
Suspension & Brakes
May 20, 2013 02:28 PM
lmike6453
Jun 4, 2008 07:15 PM
JDM978
Oct 1, 2006 06:30 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
clin20
Jun 7, 2004 01:15 PM
