Does amount of cranks effect compression tests?
Old Jun 14, 2007 | 01:20 PM
goldegg's Avatar
Default Does amount of cranks effect compression tests?
My compression numbers are all fine, however I had to crank about 8-9 times each cyl to get it to go to 212 psi on a b16 just about across the board (+-2)
The package my tester came in said 5 cranks but at 5 it was around 190 psi?
What does honda-tech say about this?
Old Jun 14, 2007 | 01:27 PM
JDMFantasy2k's Avatar
Default Re: Does amount of cranks effect compression tests? (goldegg)
5 is accurate, it's like blowing up a balloon to measure the capacity of your lungs. If you blow 5 breaths and the balloon grows to a 5 inch diameter, and another guy blows 5 breaths into the same balloon, and it grows to 8 inches, what does that tell you about your lung capacity? Same idea with the compression test. You cranking a million times to hit over 200 would be the same as taking 15 breaths to get the balloon to expand to 8 inches, and thus means nothing. Also you need to take into account the first crank, the first number should be at least half of the final number i believe.
Old Jun 14, 2007 | 01:32 PM
Luserkid's Avatar
Default Re: Does amount of cranks effect compression tests? (JDMFantasy2k)
First number is most important, its not a matter of how high itll go in the end but how fast it gets there. I always do 3 turns because that tells me more then enough if its going to be a healthy motor or a junker.
Old Jun 14, 2007 | 01:44 PM
schardbody's Avatar
also, doing it with the throttle wide open if there is an intake manifold/throttle body attached will affect the reading. operating temp and WOT is the most accurate.
Old Jun 15, 2007 | 01:58 PM
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">also, doing it with the throttle wide open if there is an intake manifold/throttle body attached will affect the reading. operating temp and WOT is the most accurate.</TD></TR></TABLE>
yup forgot that
92BlackSi
17
Apr 10, 2005 07:30 PM
builtprelude
Jan 22, 2004 10:49 PM
obsidianG35
Aug 20, 2003 02:04 PM
not so civic
Aug 29, 2002 05:09 PM
Cyber ITR
Feb 12, 2002 03:19 PM
