how do you turn down a turbos psi?
Just to add to what nonvteclude was saying. The lowest boost you can boost would be whatever your wastegate spring is. For example, if you have a 7 psi spring and using a boost controller to boost 12 psi, then you can turn the boost controller down anywhere from 12 to 7 PSI. You cannot go lower then what is in your wastegate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">Just use the adjustment ****, its on the vtak indicator, just below the nos port.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanmcdermit »</TD></TR><TR><TD CLASS="quote">i just bought a turbo for a f22 amd its set at 14.7 psi. i was looking to run it around 6 or 7. how do you turn it down?</TD></TR></TABLE>
post ur setup and how much was the cost?
vg7z
Sep 20, 2006 08:27 PM
yusoslo
Jul 12, 2003 08:01 PM
