Headlight Removal?
Alright i know im going to get flamed or whatever...but how the hell do you get the actual headlights out...does the bumper have to come off???
Last night i took the top 2 10mm out and there felt like there was something else holding the light in....i dunno
and is there any kind of diagram...YES ive searched
thanks for any positive help guys
I've never done it before, but I'm thinking it would be very similar to the civic. I would imgine there would be some plastic clips underneath the bumper, then 2 phillips screws on the sides of the bumper, a few clips on top of the bumper by the grill, and it should pull right off (There may be some clips you have to remove that hold the fender liner in place, maybe). Do this carefully so you don't scratch the bumper. Then you should have access to the 10mm bolts on the bottom that attatch the headlights and the bolts you've already removed on top and then you're done
best i could find... this is off a 2002 manual... im not sure if its the same but if it isnt you can tell us
http://www.hondafitjazz.com/ma....HTML
and yeah according to this.. step one is remove the bumper =\
and for future reference... this is the link to the manual.. it says Honda Jazz Fit Service Manual (2002 onwards).. im sure its not useless to us here in the US
http://www.hondafitjazz.com/manual.htm
the bumper has 2 screws on each wheel well. It has 5? clips up top that you pop off with a flathead screwdriver, then theres i think 7 underneath.
It only takes me about 5 min to take off everything.
O yea, the sides of the bumper clip in to underneath the headlight, when you pull the ends it sounds like cracking clips but dont worry its just unclipping.
Okay i'm in the same boat as Tight Fit...i want to install my h.i.d. kit but dumbass honda makers don't make it easy...does anyone know of a website where i can see step by step pix of the front bumper/headlight removal for a '08 Fit Sport???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bfmed1961 »</TD></TR><TR><TD CLASS="quote">i want to install my h.i.d. kit but dumbass honda makers don't make it easy</TD></TR></TABLE>
Why should they?
Bumper removal is about one of the easiest things to do. I can yank the front and rear in under 10 minutes.
Why should they?
racerxfactor
Mar 12, 2007 05:08 AM
97LXAcc0rd
Jul 28, 2005 09:20 PM
