Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Password:JDM Upgrade Injector Jumper
Old Jun 14, 2007 | 10:41 AM
passwordjdm's Avatar
Default Password:JDM Upgrade Injector Jumper
When you’re trying to run bigger injectors, chances are you will need to get them from a place other than the dealer. Chances are they will be a Bosch style injector, and probably won’t fit with the injector pigtail harness in your engine bay. The solution has always been to cut and rewire your engine loom. The Password:JDM Upgrade Injector Jumper kit is an easy low cost solution to your problem. Our solution makes life simple for you. Totally Plug n’ Play, these Jumpers will save you a lot of time.
The Password:JDM Upgrade Injector Jumpers is a quick solution to your problems without having to spend half a day cutting and splicing engine looms just to run bigger injectors. Grab a set of these and you can spend the half day you saved on doing something else. Made of all OE plugs, these Jumpers will give your engine bay that nice clean appearance that sets you apart from all the rest.
A simple product that serves a specific purpose, the Password:JDM Upgrade Injector Jumpers are a must for anybody running high HP Hondas. Clean and simple, nuff said.
Jumper Harness kits sold in packs of 4
Available in:
15cm long
20cm long (for specific cars with wire tucks)
http://passwordjdm.com/Passwor....aspx
boostedteg4dr
Nov 30, 2013 01:17 PM
ZoominNewman
Jan 30, 2011 06:23 AM
Threads
Jan 4, 2007 04:18 PM
Spade
Feb 8, 2006 06:05 PM
NitrousB.I.G.
Nov 9, 2004 06:27 PM
