B-series Intake Flanges Available!
Old Jun 14, 2007 | 09:25 AM
S9i1R's Avatar
Default B-series Intake Flanges Available!
I just had an Intake flange cut. If there is anybody interested hit me up on here.
I'll get pics up after work...
Old Jun 14, 2007 | 09:35 AM
mwieczorek43's Avatar
Default Re: B-series Intake Flanges Available! (S9i1R)
Pretty sure this doesnt belong here.
and the for-sale link in your sig goes to an "edit post" page
Old Jun 14, 2007 | 11:45 AM
S9i1R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R &raquo;</TD></TR><TR><TD CLASS="quote">I just had an Intake flange cut. If there is anybody interested hit me up on here.
thanks for the heads up on the sig.
well I was posting it here since I fabed it up for the ITB's i'm working on for my motor. I'm not trying to sell these I just know in the past there have been people trying to source these intake flanges with not very much luck. Sorry if the title is misleading. I will delete it if need be.
Old Jun 14, 2007 | 02:39 PM
S9i1R's Avatar
this was cut out of 3/8" 6061 Al
to this I'm attaching the hayabusa ITB's. I need to get some tubing for the runners then I'll be set.
Old Jun 14, 2007 | 03:09 PM
PSI2HI's Avatar
Former Vendor
What motor is this for B16 or B18?
Modified by PSI2HI at 1:34 AM 6/15/2007
Old Jun 14, 2007 | 03:22 PM
S9i1R's Avatar
Default Re: B-series Intake Flanges Available! (PSI2HI)
this is for a B16 head
Old Jun 14, 2007 | 04:37 PM
RCautoworks's Avatar
Make a d, and I'll be all over that.
Old Jun 14, 2007 | 05:49 PM
GarageAlchemist
Guest
Posts: n/a
Default Re: B-series Intake Flanges Available! (RCautoworks)
price, why didn't you add injector holes ?
Old Jun 14, 2007 | 06:21 PM
*Boostwerks*'s Avatar
Default Re: B-series Intake Flanges Available! (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">price, why didn't you add injector holes ?</TD></TR></TABLE>
Price, and feasability I'm sure. The plate would need to be almost twice as thick, and the CNC time would be increased dramatically. It's easier to CNC a flat flange, and just have the bungs welded onto the runners...
which is why SLS deserves so much props for his work.
Old Jun 14, 2007 | 08:58 PM
CoreyR's Avatar
Default Re: B-series Intake Flanges Available! (Boostwerks.com)
i think hes talking about the injector humps in the port. where the injector bung will go.
Old Jun 14, 2007 | 09:32 PM
RC000E's Avatar
Default Re: B-series Intake Flanges Available! (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">i think hes talking about the injector humps in the port. where the injector bung will go. </TD></TR></TABLE>
Was wondering this myself. He says he's running it with ITB's, so I assumed he may be welding up the head and going for the further upstream injector placement. Assumption is the mother of all f*ck ups though.
Old Jun 15, 2007 | 07:40 AM
S9i1R's Avatar
Default Re: B-series Intake Flanges Available! (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">
Was wondering this myself. He says he's running it with ITB's, so I assumed he may be welding up the head and going for the further upstream injector placement. Assumption is the mother of all f*ck ups though.</TD></TR></TABLE>
your assumption is correct. I'm placing the injectors at the throttle bodies for better atomization of the fuel. plus this was cut on a water-jet...
Old Jun 16, 2007 | 09:14 AM
89crxhf's Avatar
what type of waterjet was used to cut that? how about a side shot of the flange to see edge? looks great and post up pics when your done. How did it cost you?
Old Jun 18, 2007 | 12:01 PM
kommon_sense's Avatar
your assumption is correct. I'm placing the injectors at the throttle bodies for better atomization of the fuel. plus this was cut on a water-jet...</TD></TR></TABLE>
Be careful with that. Take a look at how a lot of bike itbs are setup (i.e. cbr 600rr). They use 2 sets. One aimed directly at the back of the valve and the other upstream for better atomization. The upstream injectors aren't even used at low/mid rpms. Point here is that only using the upstream could hurt low-end and midrange.
Good luck on your setup.
Old Jun 18, 2007 | 06:20 PM
dfoxengr's Avatar
Default Re: B-series Intake Flanges Available! (kommon_sense)
6061, especially T6 isnt the most weld-friendly material. i wouldve gone with 2024 but good luck with it.
Old Jun 19, 2007 | 04:43 PM
tepid1's Avatar
Default Re: B-series Intake Flanges Available! (dfoxengr)
I've never had a problem with 6061 T6.
Modified by tepid1 at 10:14 AM 6/20/2007
Old Jun 19, 2007 | 05:30 PM
tony1's Avatar
Default Re: B-series Intake Flanges Available! (tepid1)
6061 T6 is one of the best welding types of aluminum i've welded, you must have had something different or another problem.
Old Jun 19, 2007 | 07:00 PM
dfoxengr's Avatar
Default Re: B-series Intake Flanges Available! (tony1)
its easy yes, but it is prone to fatigue cracking due to it losing its temper by the welding. i dont feel like arguing, its just the properties of it. you guys can research it more if you like
Old Jun 19, 2007 | 07:40 PM
KFMRC's Avatar
First off 2024 is not considered a weldable alloy!!!!!!! The other thing is that most manifolds are made with flanges of 6061. It is a good machining and welding alloy.
Old Jun 19, 2007 | 11:17 PM
HickamHatch's Avatar
Default Re: B-series Intake Flanges Available! (KFMRC)
The company i work for builds waterjets. Who made the waterjet machine?
Old Jun 20, 2007 | 04:49 AM
dfoxengr's Avatar
yeah youre right, 2024, not weldable. getting my numbers confused again.
abnaasefmb
Welding / Fabrication
Mar 9, 2010 02:11 PM
Pooper
Sep 14, 2006 06:00 PM
EJtypeR
May 29, 2006 03:16 PM
redzcstandardhatch
Sep 9, 2005 03:34 PM
