headlight removal?
Old Jun 14, 2007 | 08:26 AM
innes887's Avatar
Default headlight removal?
i have alot of moisture in my headlights on my 89 crx dx. does anyone know how to take them off? a pic would be very helpful. thanks
Old Jun 14, 2007 | 08:43 AM
crx_si-r's Avatar
Default Re: headlight removal? (innes887)
very simple procedure....
- take off the screws that are by the tires (2 flat screws on each side)
- take off turn signals (bumper lights)
- remove 2 12mm bolts behind each bumper light holding the bumper support in place
- remove corner light 2 philips scew
- remove 2 10mm bolts from the top of the headlight on either side of the fan relays (passenger side)
- remove 2 more 10mm bolts on the bottom the head light bracket.
- swap the headlight
- redo everything backwards and ur done.
Old Jun 14, 2007 | 11:41 AM
innes887's Avatar
thanks for the info. does this involve removing the bumper?
Old Jun 14, 2007 | 11:46 AM
SIred91's Avatar
Rainman
Default Re: (innes887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by innes887 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info. does this involve removing the bumper?</TD></TR></TABLE>
Yes, you have to take off the bumper cover....it is very easy..
Old Jun 14, 2007 | 11:47 AM
innes887's Avatar
oh ok thanks for the help/info
RA61825
May 18, 2009 07:20 PM
azian21485
May 11, 2004 08:13 AM
IEATLINT
Jun 24, 2003 04:19 PM
2k1_ITR_0736
Feb 13, 2003 03:57 AM
kshymkiw
Nov 28, 2002 07:16 PM
