Race motor forsale
b18c5 block resleeved(thicker)and bored to piston specs. ITR crank, Eagle rods (gsr stock length). Endyn 84.5mm 13.1:1 compression pistons. Honda crv head gasket. head and block sealed off for vtec oil passage(crv gasket doesn't have this. GSR head worked extensively and i do mean extensively included filled and port matching to twm ITB's and cloverleafed. head milled roughly 3-5thou to clean(literally) the surface. .5mm oversized ferrea valves. Toda valve springs. Portflow titanium retainers. Toda Spec C cams. Toda second gen cam gears. TWM 50mm Individual Throttle bodies. TWM fuel regulator. TWM 440cfm injectors. Toda Oil pump gear. Unorthodox underdrive pulley. Toda flywheel. Clutchmasters stage5 clutch package with extreme Pressure plate. DFI fuel management. MSD 6al. MSD rpm activation switch for vtec activation. MSD distributor cap. Jacob's Electronics Ultra coil. MSD 8.5mm wires. Oil line routed from block to head(remember the block off). 9200rpm ignition and fuel cutoff. Comes with endyn/moroso crank breather system as well. Motor has just been freshened with new rings and headgasket. last dyno was 246 with 165 before tuning. i'd anticipate 260 with 170 once this motor gets tuned further. Motor will come with a Toda header or possibly arrangements can be made for the motor to come with a prototype Hytech header(only one like this) for an additional cost and arrangments with Hytech. Motor can come with a tranny if needed. 1 full pass made with new setup untuned. 12.4 @ 108mph at 2300lbs with light launch granny shifting. diff let go on this run at some point as well. fresh tranny is on car now. You can hear the car run...and if i can...i'll take ya for a very short quick spin.
offers welcome. prefer local and willing to pickup. If you can't pick this up....it is solely your responsibility to make shipping arrangements(i just was made aware by a friend that he can help me with shipping arrangements(at buyers cost)) and motor will not be shipped til payment has cleared. This is not your everyday sale....this is for someone looking for *****...and has them.
if your a bonehead and wish to reply or IM me telling me you can do this setup yourself....feel free to do so...and good friggin luck.
additional contact info if needed
AOL IM ALLMOTOR1
Email ALLMOTOR11@excite.com
AOL IM ALLMOTOR1
thanks for that compliment
ryan...plankton is da chit
10k or BO. trades or partial trades considered. No...i did not daily drive this motor. if you can get past smog and put an exhaust system to this....just turn timing down and fuel pressure and be on your way.
wiring isn't dat messy no mo. DFI has alot of wires and the stock ecu harness prettymuch isn't used. so there is alot of extra to be tied up neatly in the corner
johnny you got that **** wrong.....
the order of who owns who's *** is....
sandy
sponge bob
patrick
Kelp(in swarms)
mr crabs
Larry
plankton
squigward
I'm missing some cause i forget some names...like mr. crabs niece who is a whale....etc.
lol. damn i watch that **** too much with my boy
sandy
sponge bob
patrick
Kelp(in swarms)
mr crabs
Larry
plankton
squigward
http://www.todaracing.com/drag.html its here as well.
http://www.hytechexhaust.com/honda/content_drag.htm one of those guys is me.
pay the price...make the arrangements and she is outta here!!! As long as its paid for i'd probably prefer the motor to not be local so my friends can win. lol
