car won't start
Old Jun 14, 2007 | 06:49 AM
boosted_lude's Avatar
Default car won't start
Honda-Tech i need your help. I have a 00 si and did a gsr swap. But sitting still the car will not start by turning the key. But if I do a push start and force it the car will start and run. Run strong and but will not hold idle. I have a friend with an Si also with a swap. He came by and i used his starter, dizzy, ecu, fuel pump, and main relay. Still getting the same problem. The car turns but is dumping too much fuel fouling out my plugs and top of pistons are wet. Clean out plugs and check for spark. Getting good spark. I am now stump.
Old Jun 14, 2007 | 07:02 AM
IIXtremeHansen's Avatar
Default Re: car won't start (boosted_lude)
when you turn it over it cranks or no crank? if it dosnt crank its electrical.You also check all the relay like the one in your fuse box and 2 on the bottum dash? damn too many peeps having starting problem haha including me.
Old Jun 14, 2007 | 07:58 AM
Default Re: car won't start (Dickies_N_FlipFlops)
it just turns over no crank. i've checked the fuses under the hood and the one under the driver side dash board. even if they were not blown out. i still changed them with new ones.
Old Jun 14, 2007 | 08:00 AM
1.6vx's Avatar
have you checked your timing?
And check all your grunds just in case.
Old Jun 14, 2007 | 08:03 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I agree to check the grounds. If the car has a ground to the thermostat housing, check that too.
Old Jun 14, 2007 | 08:05 AM
1.6vx's Avatar
also check all your connections on your intake mani and censors. Check with your friends harness and make sure you got all connections on ther right plugs.
You test light it? Check to see if your ignition is sending power, relay to ignition.
also where you open your hood and them big plug next to the clutch cylinder nearest to the driver fender. if u would check the big black wire both side of the clips. check if they send power if not theres a short maybe somewhere under your dash, relay to ignition not getting power. make sure everything send signal when you test it.
Old Jun 14, 2007 | 08:17 AM
I've checked timing when i was doing my valve adjumstment. I checked all my ground points and even clean up the area with a wire brush. Then sprayed some battery protective on it. I have a test light and a voltage meter. On the wire harness which goes to the dizzy and the big plug. Which one is suppose to have 12 volts continuously? Do you have a pinout?
Old Jun 14, 2007 | 12:15 PM
anyone?
Old Jun 14, 2007 | 01:32 PM
Mingo's Avatar
i'm having the same problem...when i do a push start it starts up...one of my homie said it could be my ground since i painted my engine bay...but i'm still trying to figure it out
99Ek_Fred
Jul 26, 2018 11:53 PM
olschool92
Jul 25, 2011 02:38 PM
HEADS OR TAILS
Jun 13, 2010 07:08 PM
gt35rSI
Apr 22, 2009 05:05 PM
solk1dd
15
Feb 7, 2005 01:50 PM
