Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Regular or Super?
Old Jun 14, 2007 | 05:31 AM
yakuzastyle's Avatar
Default Regular or Super?
I have a Honda Pilot 2007. Does it matter if I use regular (87) or super (93) gasoline?
Old Jun 14, 2007 | 05:54 AM
DaiJekBok's Avatar
Default Re: Regular or Super? (yakuzastyle)
The Pilot is tuned to use 87 octane, so there's no need for anything higher.
Old Jun 14, 2007 | 08:46 AM
Ross 2.0's Avatar
In a Junkyard near you.
after a few tank fulls the car can adjust to it but it's not really worth the cost with gas prices like they are.
Old Jun 19, 2007 | 11:09 AM
20Ody00's Avatar
My Odyssey manual says the Van will run on both but will have more HP with the 93 octane. You may have the same setup...so will you get back the extra cost in MPG??? You would have to do a comparison test with a minimum 4 tanks each of the two octanes that you are looking at to make sure that you are not mixing the two getting different readings...I would consider the first two tanks after a switch between tanks a wash since there maybe residual fuel from the previous fill-ups...my father used to mix the two all the time with a fillup of 87 then a half tank of 93 then back and forth...don't think he checked his mileage though but that was his thing...
Old Jun 22, 2007 | 07:40 PM
golf's Avatar
Default Re: Regular or Super? (20Ody00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20Ody00 &raquo;</TD></TR><TR><TD CLASS="quote">My Odyssey manual says the Van will run on both but will have more HP with the 93 octane.</TD></TR></TABLE> Eh ???... how does that work ???
93 octane has no more power value than 87 octane.
Fg2_herrera805
Honda Civic (2006 - 2015)
31
Apr 26, 2012 07:28 AM
SlowEJ8
48
May 2, 2009 06:44 AM
Eg2Love
30
Sep 19, 2008 10:27 PM
hometheaterman
Apr 16, 2006 02:02 PM
bearboy80
Apr 24, 2003 08:26 AM
