SOHC Problems
Old Jun 14, 2007 | 05:20 AM
civic_jdm16's Avatar
Default SOHC Problems
OK My buddy has a 93 hatch cx with the D16B2 ok we jus t put a Z6 in the car and it won't start... We used the 1.5 harness, and are running the P28 computer.
We are getting spark but it not to strong and Great fuel...
Any thoughts??????????
Old Jun 14, 2007 | 06:12 AM
teal_dx's Avatar
Default Re: SOHC Problems (civic_jdm16)
check all your grounds. valve cover, tranny, and thermostat
Old Jun 14, 2007 | 08:32 AM
Default Re: SOHC Problems (teal_dx)
Did that already....
Old Jun 14, 2007 | 08:34 AM
highrev1987's Avatar
you might have wired the starter backwards does is sound like the fuel doesnt stop priming, put your hand on the starter and check if it is hot
Old Jun 14, 2007 | 08:36 AM
teal_dx's Avatar
Default Re: SOHC Problems (highrev1987)
does the motor sputter or try to start at all? or does it just crank with no signs of starting?
Old Jun 14, 2007 | 09:10 AM
Cranks with no signs of starting...
Oh yea How in the F^CK do you wire a starter backwards.
Old Jun 14, 2007 | 09:27 AM
yoffer's Avatar
Banned
are the spark plug wires in the correct order?
Old Jun 14, 2007 | 09:35 AM
Default Re: (yoffer)
does the fuel stop priming?
Old Jun 14, 2007 | 11:16 AM
Default Re: (highrev1987)
Yes plug wires are in the correct order
getting great fuel
Old Jun 14, 2007 | 11:52 AM
teal_dx's Avatar
Default Re: (civic_jdm16)
can you borrow a distributor to test with? maybe the ignitor or coil inside yours is bad
Old Jun 14, 2007 | 11:58 AM
Default Re: (teal_dx)
Yes that is what I have been thinking all along...
fooboo
May 22, 2010 01:53 PM
trevorjohn88ef
Oct 20, 2007 06:55 PM
John.
May 25, 2006 06:10 AM
pistol
Oct 7, 2003 08:56 AM
crashtest Sonny
31
Dec 2, 2002 06:27 PM
