car vibrates when in reverse
Old Jun 14, 2007 | 03:07 AM
jonathanraycamacho's Avatar
Default can you tell me...
why does my car vibrate a lot when im in reverse? dude pls get back to me asap! thank you.
Old Jun 14, 2007 | 03:18 AM
Schmitey's Avatar
Default Re: can you tell me... (jonathanraycamacho)
I'm assuming this is a manual? You don't exactly give us much to go on!!!
Give it higher RPM's...reverse is geared down the lowest. There's also no synchro on it so come to a stop/let RPM's drop before putting it in reverse.
It is also possible to drive without reverse. I did it once for about 3 months...you just have to be careful where you park.
Old Jun 15, 2007 | 05:02 AM
Default Re: can you tell me... (Schmitey)
thats funny. well its an auto, and i was wondering if i have to worry about it later...
Old Jun 15, 2007 | 06:39 AM
Patman's Avatar
I think I'm having a similar problem you are, is it a rattle? I think its my cat heat shield
Old Jun 15, 2007 | 06:41 AM
CARMandP's Avatar
Default Re: (Patman)
Check the front motor mount. Most likely broken. The one in the middle of the engine right between the radiator fans. Usually breaks the top of the mount. Pull the small rubber flap on the side and look at the mount. Most likely split. common.
turboblack2door
Jun 8, 2011 02:50 PM
pinkspider
Dec 10, 2008 06:38 PM
dan200
Feb 25, 2008 10:30 PM
stackz
Nov 15, 2006 01:04 PM
dxasylum
May 2, 2006 09:44 AM
