FS: USDM Integra Type-R 5 lug brake conversion, 32mm, extended studs
Old Jun 13, 2007 | 11:19 PM
n1_egsex's Avatar
* B A N N E D *
Default FS: USDM Integra Type-R 5 lug brake conversion, 32mm, extended studs
i'm selling my set of brakes that i had my old hatch
usdm itr 32mm 5 lug conversion
pads and rotors are still good, bites hard
extended studs up front
abs sensors are still intact
has itr ebrake cables (you can use these on eg's also, thats what i used)
this is the 32mm version meaning you can use it even if you have a SOHC, plus axles are easier to find
price is $1000 picked up FIRM
i also have a set of rota gt3's 16x7" red 5 lug that could go with this setup, $250/set if you buy it with the 5 lug, $300 if you buy it seperately, wheels are pretty clean, 2 have very small curbs, 2 are clean, tires need to be replaced from camber wear
415-676-9544
Modified by JJSpecTuning at 12:08 PM 6/20/2007
Old Jun 14, 2007 | 12:11 AM
rookshot06's Avatar
Default Re: FS: USDM Integra Type-R 5 lug brake conversion, 32mm, extended studs (JJSpecTuning)
Old Jun 14, 2007 | 09:02 AM
n1_egsex's Avatar
* B A N N E D *
Old Jun 14, 2007 | 09:14 AM
Airbag Club's Avatar
sick..
Old Jun 14, 2007 | 09:49 AM
n1_egsex's Avatar
* B A N N E D *
Default Re: FS: USDM Integra Type-R 5 lug brake conversion, 32mm, extended studs (ARC Magic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARC Magic &raquo;</TD></TR><TR><TD CLASS="quote">sick..</TD></TR></TABLE>
Old Jun 14, 2007 | 02:44 PM
n1_egsex's Avatar
* B A N N E D *
bumpo for cinco lug
Old Jun 14, 2007 | 03:40 PM
BlUeDC2nEr's Avatar
Old Jun 14, 2007 | 06:20 PM
RyCeRoCkeTz's Avatar
Default Re: FS: USDM Integra Type-R 5 lug brake conversion, 32mm, extended studs (BlUeDC2nEr)
Old Jun 15, 2007 | 10:04 AM
n1_egsex's Avatar
* B A N N E D *
Old Jun 15, 2007 | 04:53 PM
n1_egsex's Avatar
* B A N N E D *
Old Jun 16, 2007 | 09:45 PM
n1_egsex's Avatar
* B A N N E D *
bump!!!
Old Jun 17, 2007 | 07:32 PM
n1_egsex's Avatar
* B A N N E D *
Old Jun 17, 2007 | 10:33 PM
jdm biker's Avatar
bump
Old Jun 18, 2007 | 03:40 PM
n1_egsex's Avatar
* B A N N E D *
OGI8UUP
May 2, 2023 10:03 AM
JDM_DAKiD
May 21, 2014 08:36 PM
JDM_DAKiD
Northeast (Sales)
May 21, 2014 06:28 PM
JdMeF9SiR2
Mar 31, 2006 10:35 AM
b18c-rDC2
Jan 30, 2004 08:50 PM
