4 wire o2 hook up
Old Jun 13, 2007 | 10:27 PM
vw eater's Avatar
Default 4 wire o2 hook up
hello i have a crx w/ obd-1 conversion and was woundering if it is possible to hook up the 2 black wires backwerds?i hard wired the o2 sensor in and was woundering if it mattered how they were hooked up, i have a code for o2 sensor a
thnaks
Old Jun 14, 2007 | 09:14 AM
EF_LSVtec's Avatar
Default Re: 4 wire o2 hook up (vw eater)
This is how I wired mine...Use the one on the right.
Old Jun 15, 2007 | 01:01 PM
vw eater's Avatar
Default Re: 4 wire o2 hook up (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">This is how I wired mine...Use the one on the right.
ok thanks, i will try that and see what happens, what iam woundering is i had my other crx w/ b16a w/ the same harness and i used the conversion harness and i spliced the same wires w/ no problem, the other o2 sensor had a green this wires has a blue
thanks for the help
Corksil
Jun 6, 2012 05:09 PM
DEPintheCurve
Aug 19, 2008 11:38 AM
Hondamonster
12
Jun 21, 2007 08:19 PM
SI_Ro
Jan 12, 2004 06:43 AM
Turbo88hatch
Feb 16, 2003 09:21 AM
