its it ok to lower the car without camber kits??
Old Jun 13, 2007 | 10:01 PM
ShinotakuX's Avatar
Default its it ok to lower the car without camber kits??
I just want the tokico hp shocks with tein s-tech lowering springs. would that be a great combo for lowering civic coupe ex???
Old Jun 13, 2007 | 11:20 PM
pkdog167's Avatar
Default Re: its it ok to lower the car without camber kits?? (ShinotakuX)
you need the camber kit or your wheels will fall off.
Old Jun 13, 2007 | 11:49 PM
solattack77's Avatar
Default Re: its it ok to lower the car without camber kits?? (pkdog167)
does this also apply to the del sol???
Old Jun 13, 2007 | 11:54 PM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">you need the camber kit or your wheels will fall off.</TD></TR></TABLE>
depends on how low you want to go.... Get an aligment after you drop your car... expect to see some camber wear along the way
Old Jun 13, 2007 | 11:55 PM
pkdog167's Avatar
Default Re: its it ok to lower the car without camber kits?? (solattack77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solattack77 &raquo;</TD></TR><TR><TD CLASS="quote">does this also apply to the del sol???</TD></TR></TABLE>nah, i was just kidding..........you don't need a camber kit to lower your car. Camber kit is to corret the negative camber that created when the car is lowered. Negative camber will make uneven wear on the tire. Also when you lowered the car, you will change the toe too, the toe is what make the tire have uneven wear the most. If you lower your car, just go to the shop and tell them to set the toe to zero, you don't really need a camber kit.
Old Jun 14, 2007 | 12:43 AM
ventturei27's Avatar
well you dont need them right away- ive had my car lowered about 2" all around, i have 2.5 neg camber in the front and 1.9 in the rear. the only thing it does is waer your tires faster. camber makes your tires sit an an angle to the road, you use the camber kit to make them sit flat against the road.
its going to be a very good idea in the mid - long run to get a camber kit
Old Jun 14, 2007 | 01:42 AM
97civicdx's Avatar
I am running the stechs on my 97 coupe. I dont have a camber kit and the alignment fell just short but acceptable of factory spec. Toe will need adjustment. I dont notice any camber wear on the oe 185/65 tires and the car is my daily driver. Actual drop from those springs came to 1.5 front and 1.7 rear.
Measure fender height at stock height and same point after spring install and again like a month later as springs settle.
Good luck
Old Jun 14, 2007 | 02:04 AM
mikeycivic's Avatar
Default Re: its it ok to lower the car without camber kits?? (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">If you lower your car, just go to the shop and tell them to set the toe to zero, you don't really need a camber kit.</TD></TR></TABLE>
x2
Old Jun 14, 2007 | 03:17 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: its it ok to lower the car without camber kits?? (mikeycivic)
Camber kit won't be necessary for the front or rear IMO.
The rear camber can be fixed enough to not matter with a few washers. The front camber won't be bad enough to need fixing unless you're dropped more than ~3".
Camber kit Shmamber kit.
The key in any 2.5" or less drop is setting the toe to factory spec and adding a few washers to the rear uca's. It's safe and a lot cheaper than the ingall kit. Which is just fancy bolts and washers.
Old Jun 14, 2007 | 05:36 AM
96hb's Avatar
Yes it is fine. Those springs don't drop that much anyways. I've been on Ground Controls for over 2 years dropped 2.5-3", no camber kit (although I did the washer shim in the rear) and my car drives fine with no uneven tire wear to speak of. All you gotta do to maximize your tire life is get an alignment done and get the toe set as close to factory spec as possibe.
Old Jun 14, 2007 | 09:35 PM
The Si's Avatar
Default Re: its it ok to lower the car without camber kits?? (96hb)
No you Don't..
Old Jun 14, 2007 | 09:48 PM
turborsti's Avatar
If you have wear from camber then your not cornering hard enough.
Old Jun 14, 2007 | 09:50 PM
92hatch_cx-t's Avatar
Default Re: its it ok to lower the car without camber kits?? (TheSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSi &raquo;</TD></TR><TR><TD CLASS="quote">No you Don't..</TD></TR></TABLE>
X2
Old Jun 14, 2007 | 10:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">nah, i was just kidding..........you don't need a camber kit to lower your car. Camber kit is to corret the negative camber that created when the car is lowered. Negative camber will make uneven wear on the tire. Also when you lowered the car, you will change the toe too, the toe is what make the tire have uneven wear the most. If you lower your car, just go to the shop and tell them to set the toe to zero, you don't really need a camber kit.</TD></TR></TABLE>
thanks dude, i was curious cause im picking up some neuspeeds later this month
Old Jun 14, 2007 | 11:16 PM
kos99ngel's Avatar
good ******* ****!!!!!!!!!!!!!!!
Old Jun 15, 2007 | 02:54 AM
Pr0ject93hb's Avatar
Default Re: its it ok to lower the car without camber kits?? (kos99ngel)
expletive a camber kit...just get camber fluid instead of brake fluid and run that. its like viagra for cambered wheels, straightens them right out.
sure its okay to lower your car with a camber kit, but is it OKAY to wear your tires fast?
hondahp21
Dec 27, 2006 12:36 AM
h22a41997
Dec 15, 2006 05:29 PM
BLUE EH3
Suspension & Brakes
Jul 10, 2005 09:00 PM
bearboy80
May 9, 2003 01:50 AM
xstalkrx
Apr 24, 2003 05:37 AM
