INTEGRA SI BLUE WITH 2001 FRONT END WITH LOTS OF EXTRAS!!!HID'S,JDM,TYPE-R PARTS
JUST PUTTING MY BIG TOE IN THE POOL.PLEASE PM OFFERS AND BUMP IF VIEW.THANKS
-TSX H.I.D. Retrofit headlights!! HID'S!!!
-TYPE-R LIP
-SI BLUE (USE TO BE WHITE BUT HAD DOOR PAINTED ALSO ON THE INSIDE)
-FLUSH MOLDINGS
-FLUSH SPOILER HOLES
-DOHC VTEC BADGE
-TYPE-R MUFFLER WITH FLAWLESS EXH. TIP
-SKUNK 2 COILOVER KIT
-TYPE-R SHOCKS (RIDES NICE AND STIFF)
-TRUNK TYPE-R BAR
-TYPE-R BLACK CARPET
-TYPE-R ARMREST ELIMINATOR
-CTR SHIFT BOOT (CLEAN WITH RED STITCHING BRAND NEW)
-2000 GSR SHIFT ****
-TYPE-R CLIMATE CONTROL *98 SPEC WITH THE BLUE IN THE CARBON FIBER!!
-TYPE-R CLUSTER *98 SPEC WITH BLUE TINT
-TYPE-R DOOR PANELS WITH TWEETER
-HOOD SPACERS (KEEPS MANIFOLD COLD SO THE AIR IS NOT JUST HITTING THE FIRE WALL)
-ENKEI RPF1 RIMS WITH NEW FALKEN TIRES 16/205/50 (WHITE)
ENGINE MODS:
I have a clean setup for sale. The motor was built by my good friend Jon Tanji. DOHC GARAGE. the motor was in my EK hatch. It runs very strong and only has 42,xxx miles on it. Everything that has been put on the motor is brand new and all came from DOHC GARAGE.
- 2001 GSR head!!!! -Not type-r
- Skunk2 manifold
- CTR intake cam and stock GSR exh. cam
- Type-r valve cover
- Type-r dizzy
- NGK plugs & NGK wires
- Toda timing belt
- New HONDA fuel filter and HONDA GSR fuel injectors
- B16A2 BLOCK
- Type-r water pump
- Toda oil pump gear
- New piston rings (stock b16 rings) HONDA
- B16 Trans hydro came from my 2000 civic SI
- JUN flywheel
- Excedy street clutch
- GSR axles
Modified by liftedresearchgroup at 12:35 AM 6/16/2007
-TYPE-R LIP
-FLUSH MOLDINGS
-DOHC VTEC BADGE
-TRUNK TYPE-R BAR
ENGINE MODS:
- Skunk2 manifold
- Type-r dizzy
- Toda timing belt
- B16A2 BLOCK
- Type-r water pump
- JUN flywheel
- GSR axles
EViLSTAR
Mid-Atlantic (Sales)
22
Nov 4, 2010 06:10 AM
hgem1si
Oct 8, 2009 07:45 PM
BlueIntegraBoy
Jul 11, 2009 12:06 PM
liftedresearchgroup
Jul 5, 2007 07:38 PM
