How to adjust headlights in a 00 ex coupe.
I did a search and nothing came up. Ever since i lowered my car ive wanted to raise the headlights some so i can see better. I cant figure out how to do that on my 00 ej8. I searched and found nothing. Anyone done this before? I know its probably real damn easy.
Mike
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">I did a search and nothing came up. Ever since i lowered my car ive wanted to raise the headlights some so i can see better. I cant figure out how to do that on my 00 ej8. I searched and found nothing. Anyone done this before? I know its probably real damn easy.
Mike</TD></TR></TABLE>
pop your hood...behind the headlights you should see a dial, theres a phillips screw right in the middle of the dial. I'm not sure which way is up/down. Try it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">which one does the left to right then?? thanks for your help tho
mike</TD></TR></TABLE>
i'm not sure if our headlights can be adjusted left to right. I know a nice set of phillips X-treme h4's will solve the problem haha.
they can be adjusted up/down left/right. there are places to stick a phillips screwdriver, that when turned will spin a gear attached to the interior mechanism. look around they arent hard to spot.
HondaLuvn
Jul 10, 2007 07:23 AM
