obd1 p72 ecu pinout
Old Jun 13, 2007 | 07:34 PM
808jdm_profileEG6's Avatar
Default obd1 p72 ecu pinout
where can I find the obd1 p72/p28 ecu pinout.i searched and found only the obd2 one.I know i found the obd 1 p72 one before but i cant find it now.i need one with pictures for the plugs and what number they are like A6 etc.thanks
Old Jun 13, 2007 | 07:37 PM
numbnuts22715's Avatar
Default Re: obd1 p72 ecu pinout (808jdm_profileEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808jdm_profileEG6 &raquo;</TD></TR><TR><TD CLASS="quote">where can I find the obd1 p72/p28 ecu pinout.i searched and found only the obd2 one.I know i found the obd 1 p72 one before but i cant find it now.i need one with pictures for the plugs and what number they are like A6 etc.thanks</TD></TR></TABLE>
talking about this?
Old Jun 13, 2007 | 07:38 PM
whoops.. this may be better..
http://www.ff-squad.com/technet/wiring.obd1.htm
Old Jun 13, 2007 | 07:47 PM
yup exactly what i was looking for...do you know which pin I hook up the a/f ratio guage signal to?
Old Jun 14, 2007 | 01:45 AM
BlueIntegraBoy's Avatar
Default Re: (808jdm_profileEG6)
Pin D14
Old Jun 18, 2007 | 11:40 PM
kauaiboy66's Avatar
Thanks I needed this too
Old Jun 18, 2007 | 11:47 PM
1.8L_allmotormilitia's Avatar
^ pics helped 234432234234x's.
Old Aug 28, 2007 | 09:52 AM
purehonda12's Avatar
Default ems hook up
thanks i have been looking for this too.. I am geting ready to turbo my 94 gsr. I saw that you are suposted to de-pin a22 ignition control module. How come you de-pin this one with the ems? Thanks for your time.
Old Aug 28, 2007 | 09:58 AM
deftonerider's Avatar
thats very useful thanks
Old Oct 5, 2007 | 01:29 PM
20_sec.hatch's Avatar
Default Re: (deftonerider)
needed this, THANKS
Old Jul 30, 2008 | 05:29 AM
xtremeness101's Avatar
Default Re: obd1 p72 ecu pinout (numbnuts22715)
anyone know where the pin for the tach signal goes?? or does it go straight from the ignitor on the dizzy to the gauge cluster?
Old Apr 27, 2009 | 06:15 PM
civicracer94's Avatar
wtf i still dont see the rpm signal
Old Apr 27, 2009 | 06:22 PM
94EG8's Avatar
Seagull Management
OBD1 and OBD2A civics and Integras get their tach signal from the igniter in the distrbutor and from there it goes to the cluster, the ECU isn't involved. Its only OBD2B civics and integras that get their tach signal from the ECU.
Old Apr 27, 2009 | 06:26 PM
i have (obd1) 94 civic and hooking up an apexi vafc i found everything else but not where the rpm signal go ... so will i have to run this all the way under the hood to the blue wire at the fire wall ?
Old Apr 28, 2009 | 01:33 PM
94EG8's Avatar
Seagull Management
You can either do that or tap into the wire behind the cluster inside the car, your choice.
ATrin
18
Jul 31, 2006 05:38 AM
Kelly.
Jun 1, 2006 11:50 AM
fatalman
Dec 22, 2003 06:50 PM
b18c4door
Oct 24, 2003 06:56 AM
