Changing Brake Master Cylinder
Old Jun 13, 2007 | 06:57 PM
T_bones's Avatar
Default Changing Brake Master Cylinder
Anyone point me in the direction of a HOW TO on changing the Master Cylinder?
I dont searched.
Modified by TEGhasJDMfever at 8:50 PM 6/13/2007
Old Jun 13, 2007 | 09:00 PM
T_bones's Avatar
Default Re: Changing Brake Master Cylinder (TEGhasJDMfever)
Anyone?
Old Jun 13, 2007 | 09:10 PM
numbnuts22715's Avatar
you drain all the fluid
disconnect the 2 brake lines, unbolt 2 bolts
Swap it.
then bleed.
It's a fairly easy procedure...
Are you stuck on any one particular part?
Old Jun 14, 2007 | 09:44 AM
Sam92Teg's Avatar
Default Re: (numbnuts22715)
You should bench bleed the master cylinder before installation. It should come with two hoses that you use to loop back into the MC after you pour in fresh brake fluid, then you push/pull the MC piston to remove all the air bubbles. Then install. Use line wrenches so you don't bugger the line nuts and bleed the system after installation. There is also a procedure for adjusting the push rod that actuates the MC, but you probably will be ok skipping this step.
Old Jun 14, 2007 | 10:00 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Well, if you must see a DIY:
http://www.team-integra.net/se...D=992
Although not shown or talked about in the above link, I would agree with Sam92Teg to bench bleed the MC first (easier this way to get all the air out), and to use line wrenches on the nuts, to avoid rounding the nuts.
You'll still need to bleed the brake lines though, after the MC is installed.
Old Jun 14, 2007 | 10:02 AM
Exeed's Avatar
Default Re: (Sam92Teg)
I was just about to link to that.. beat me to it
Old Jun 14, 2007 | 04:37 PM
jarel's Avatar
flare nut line wrenches is a great thing to have, don't strip the nuts.
if you don't bench bleed the MC and you just bleed it after, same results will happen right? it's just easier to clear the air out if you bench bleed it right?
Old Jun 14, 2007 | 06:40 PM
Sam92Teg's Avatar
Default Re: (jarel)
You are correct sir.
prelude5blue
Suspension & Brakes
Jul 2, 2014 08:43 AM
dleccord
Suspension & Brakes
12
Feb 20, 2013 09:52 PM
kc_boss_816
Sep 9, 2009 06:17 PM
JJexpress
Apr 4, 2009 07:22 PM
BLUE EH3
Nov 28, 2005 06:24 PM
