1996 civic b18
Old Jun 13, 2007 | 01:59 PM
nix94delsol's Avatar
Default 1996 civic b18
what am i gunna need to swap my lsvtec (b18a1 mated with a b16a head) into my 1996 civic ex?
i know im gunna need mounts but what about the SOHC to DOHC vtec?
do i need a new wiring harness?
Old Jun 13, 2007 | 02:10 PM
97Ej6mike's Avatar
Get B series mounts. Your current wiring harness should work fine, but i would consider running the P72(1.8l VTEC) ecu for the LS motor. Also take into consideration that in order to keep LS/Vtec running in the long run, think about investing in a balanced crank, and new rods/pistons. For some reason, people who tend to just slap VTEC heads on a stock LS bottom end up blowing them up quickly, which is due to the fact that the LS bottom ends werent designed to be Rev-happy like the GSR and ITR blocks.
Old Jun 13, 2007 | 02:38 PM
94si94cx's Avatar
Default Re: (97Ej6mike)
DC2 mounts, with a 99-00 Si rear mount. Use your stock harness, and wire it to your engine. OBDII --> OBDI conversion harness, chipped p28.
p72s are much harder to find,
Old Jun 13, 2007 | 02:41 PM
whats a p28 0ut of?
slob20ef
Mar 27, 2009 05:29 PM
EJ6 BoOsT
Feb 18, 2009 11:17 AM
ITRiWISH
Jul 28, 2008 09:12 PM
95dsol
Mar 6, 2007 05:01 PM
B16A3Civic*Eg
May 5, 2006 08:26 PM
