Instructions on JDM Front Conv.
http://www.c-speedracing.com/howto/jdm/jdm.html
I don't know how good this is, but it's C-Speed, so it should be pretty good!!!
If anyone comes across instructions for the JDM front end conversion, please let me know. i have the front end and i want to get started on it. is it something that a couple buddies an do? or does this have to be taken somewhere professional? i live in the Richmond, VA area, and if it needs to be taken somewhere, i need names and numbers of places to call.
ANY HELP WOULD BE APPRECIATED!!
thanx
thanx
i could use detailed instructions too. the one on ipsracing.com is good but i need a parts list as well
hey nighthawk, i looked in the ipsracing site but i couldnt find the instructions in there, u think u can give me a direct link to that site? thanx
hey nighthawk, i think u asked me earlier on how much my front cost me, its all metal and costed me 1100 without front bumper
basicly you will need to:
remove in this order. Hood,turnsignals,fenderwell liners,bumper, sideskirts, headlights, fenders, ratiator, horn, A/C condensor (you'll need more freon), hood latch, hood release cable, front beam, and then have your radiator supprort cut off.
Parts: new Hood, Headlights, Fenders, bumper, Grille, Radator support, front beam, bumper support, fender brackets, headlight gaskets, foglight covers, high beam covers, side marker lights, and you will need to buy a hood latch and cable from a 93 integra so you can pop your hood.
Install in this order: Radiator supprort, Then paint, A/C condensor (re-charge A/C), Radiator (re-fill with coolant), Horn, hood latch and cable, front beam, bumper support, fenders, sidemarker lights, fender support brackets, rokermoldings, fender liners, headlights fog light covers, high beam covers, install headlight gaskets onto hood, bumper, grille, and finally hood.
You will also need to notch where the headlights go on the original inner fenders.
I would suggest shaving the emlem holes on the hood when you paint too, looks nicer.
Wiring: you can use your stock turn signal bulbs and low beams.
Turn signals, the small wedge bulb will need to be extended to your new sidemarker lights in the fender. the other larger bulb is just fine and plugs in. same for your low beam. your high beam in now a different type of bulb and you will have to cut off the stock plug and wire the new one on.
If you choose to hood up the fog lights buy the appropriate bulbs and the Integra OEM foglight kit minus the foglights to get the switch, wiring, relay etc..
good luck
good luck
Where did you buy it from? The guy who sold it to you should be able to help you out.
Ibuprofen
Nov 5, 2001 06:17 PM
