Prelude Vtec Brakes up front, Drums or Disks in the back?
Old Jun 13, 2007 | 10:07 AM
Simple SOHC's Avatar
Default Prelude Vtec Brakes up front, Drums or Disks in the back?
I have some prelude vtec brakes laying around and thinkin about installing them. I know I need a 3-5mm spacer between the disks and the hub, and to redrill the disks for the 4x100 lug pattern.
I have drums in the back now...should I upgrade to disk rears first? Yeah...the fronts do something like 70-80% of the stopping force...but would the extra large brakes in front throw off the balance too much?
Old Jun 13, 2007 | 10:10 AM
Diet coke boii's Avatar
Default Re: Prelude Vtec Brakes up front, Drums or Disks in the back? (Simple SOHC)
They have vtec brakes now....wow
Old Jun 13, 2007 | 10:18 AM
BlueIntegraBoy's Avatar
Default Re: Prelude Vtec Brakes up front, Drums or Disks in the back? (Diet coke boii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diet coke boii &raquo;</TD></TR><TR><TD CLASS="quote">They have vtec brakes now....wow </TD></TR></TABLE>
Prelude VTEC brakes have 11.1" rotors, and the lesser trims have smaller brakes in the front.
The fronts do most of the braking. I would ask BrakeExpert about this situation. If it were me, I would upgrade the rear.
https://honda-tech.com/zerothread?id=2008861
Old Jun 13, 2007 | 01:32 PM
Thnx Blue...pm'd him just now
Old Jun 24, 2007 | 09:19 PM
roastbeefrichie's Avatar
https://honda-tech.com/zerothread?id=1484555
&gt;on dx knuckles, on prelude calipers stamped 17CL15VN, you'll need to machine your brackets, replace your 9.4" rotor w/ a 10.3" (from any 90-91 ex, 90-03 teg, 99-00 si) & grind your pads to clear the rotor hat.
&gt;on ex or teg knuckles, you'll need to machine your brackets, use re-drilled prelude 11" rotors
*you'll need a bigger 1" or 15/16 master brake cylinder to push more fluid to the calipers
*you can find complete rear disc conversions on 88-00 crx/civic and 90-00 integra (not a sin if you don't, but rear discs help with nose dive)
*update your valve prop from a honda w/ rear disc if you dump your drums (also not a sin, but it helps your brake balance)
https://honda-tech.com/zerothread?id=1811368
pm brakeexpert, he machines brackets & re-drills rotors too...he does great work !
oneoffaccord
Sep 22, 2010 01:39 PM
sk8shorty012
25
Oct 31, 2007 07:07 AM
hondabigblock
Jan 18, 2006 07:38 AM
jetpilot
Dec 17, 2004 01:32 PM
misledyouth
Jul 21, 2003 06:50 PM
