Brake Disengagement Problem
Old Jun 13, 2007 | 09:42 AM
faster_thn_hell's Avatar
Default Brake Disengagement Problem
'91 CRX Si. The front right brake was staying engaged so I replaced that caliper and now it seems to have stopped(unless I didn't get all the air out of the line). Now I've noticed that the left rear brake is getting hot even when I don't use the brakes to slow down, which means that it is staying engaged. Since both those brakes are on the same circuit, that makes me think that the problem could be the proportioning valve. Or would a faulty master cylinder have the same effect? The brake system is definitely not my specialty. I need to know what could be causing this, and which part to replace.
This is my everyday driver so a quick response would be much appreciated. Thanks.
Old Jun 13, 2007 | 10:17 AM
CRX Toad's Avatar
Default Re: Brake Disengagement Problem (faster_thn_hell)
I would bleed the brakes several times first to see if that helps.
Old Jun 13, 2007 | 11:57 AM
fireant's Avatar
Default Re: Brake Disengagement Problem (CRX Toad)
It wouldnt hurt to just take the caplier off enough to remove and clean up/re-grease the two sliders.
That would take away some of the resistance to opening, but if it continues, its probably the cylinder clogged up with gunk like the other one was.
dpine
Suspension & Brakes
Jan 22, 2015 04:15 AM
hteg12
Jul 18, 2013 05:13 PM
bonspeed
Dec 20, 2009 12:34 PM
blkteggy
Mar 13, 2008 10:14 AM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
