ANYBODY KNOW HOW TO DO A VTEC CONVERSION!!!!?????
I have a 97 honda accord and my exhaust header was eroding real bad. It caused 3 of the strouts to bolt it on to break. Well now i'm trying to find someone to do it for me and im having a hard time. I have most of the parts already and the only thing i think im missing is some kind of oil line. If you've done this conversion before and your willing to give me a hand plz pm or call me at 7572857817. peace
Raj
Raj
go into the FAQ, stickied at the top of the forum, and scroll down to the Swaps section.
There you'll find a link to a write-up on how to swap on a vtec head.
its really quite easy, you take the non vtec head off the current block, then put the new vtec head on the block, and then hook all your sensors back up to the new head, the only thing you have to add is the oil pressure sensor for the vtec and the vtec solenoid which should come with the new block, then you just run the wires for those to devices to the ECU which you would also have to replace with the vtec ECU.
all the rest of the stuff is the same, just make sure you get the timing right.
hey thanks alot man... where are u at?...would u happen to be close to Norfolk Va...i would pay u to do the labor n educate as we go along...buy u some brewskies.
deadlyaccord
Jun 13, 2007 06:22 PM
