17's how bad
Old Jun 4, 2002 | 10:55 PM
95integrags-r's Avatar
Default 17's how bad
how bad will 17's hurt my times. I bought 17 tenzo poke 10 with falken azenis. will this hurt my times that bad. they are on back order, so if I want to I can change my order. thanks
Old Jun 4, 2002 | 11:04 PM
blkbeast's Avatar
New User
Default Re: 17's how bad (95integrags-r)
yes they will hurt your times. but go ahead and get them and use your stock rims for the track.
Old Jun 4, 2002 | 11:29 PM
boostin GSR's Avatar
ver ver bad
Old Jun 4, 2002 | 11:33 PM
gsxr's Avatar
Default Re: 17's how bad (BoostinGSR)
17's is where it'll start to hurt your performance. go with 16's with good rims you can have the best of both worlds. performance and looks
Old Jun 4, 2002 | 11:44 PM
frogsr's Avatar
Default Re: 17's how bad (gsxr)
agreed. in my opinion, unless you're making some serious power to compensate, i think 17" is one size too big. they look sweet though.
well I mean, I can just race around on the high way and stuff, like it wont hurt me barely at like higher speeds will it. plus I will just either race on stock wheels when it is important or I am going to the track, buy those new rota attacks and have light tires for always, or suffer the consequences of 17's. P.S. I dont think they make poke-10's n e thing smaller than 17's. also, is there n e tenzo wheels n e one would recomend swapping that are good light wheels???
thansk
Old Jun 5, 2002 | 02:40 AM
sutrusu's Avatar
it doesnt hurt times bad at all if they're lightweight. my rotas (16.5 lbs) felt the same as stock. plus they're better for cornering.
Old Jun 5, 2002 | 04:13 AM
arw321's Avatar
Default Re: 17's how bad (sutrusu)
That's wrong, 17's will hurt your times no matter how light, because of the extra rotating mass.
I have lightweight 17's on my car also, and there is a difference, it's noticeable, but you can always run smaller wheels at the track.
I wouldn't say the difference is a second in the 1/4, but maybe 2 or 3 tenths.
HTH
Adam
Old Jun 5, 2002 | 04:17 AM
Black SVT's Avatar
Default Re: 17's how bad (arw321)
Usually about half a second for 17's.It also isn't just the rotational mass.It makes your gearing quite a bit longer,which is not good in your case,aswell.
Old Jun 5, 2002 | 04:59 AM
integra*RS*'s Avatar
New User
Default Re: 17's how bad (Black SVT)
what is the usual weight of a 17" rim including the tire????
When I weighed mine, it was close to 45lbs (one rim n tire combination).
I think mine is really heavy, but i guess the car got use to it.
I chirp 2nd gear all the time, and 3rd more than often in my 17's.
Although it takes a little longer to get to higher speeds compare to my stock 14's.
Old Jun 5, 2002 | 09:06 AM
Default Re: 17's how bad (integra*RS*)
the wheels weigh around 20 pounds, and tires the same
Old Jun 5, 2002 | 11:43 AM
ShiftDown's Avatar
I personally think 17"s are too big for Integras. IMO some lightweight 16"s are best which wont hurt your acceration too much but still give you better handling.
David
Old Jun 5, 2002 | 05:18 PM
Default Re: 17's how bad (Oki_Doki)
do you have n e choisec off hand you could tell me- other then like rota stuff, cause I know about all them
thanks
Old Jun 5, 2002 | 05:37 PM
TakaIntegra's Avatar
you'll lose 4hp
Old Jun 5, 2002 | 07:27 PM
vteg's Avatar
New User
IMHO, get the 17's if you are willing to sacrifice some performance for looks. If you are a hardcore racer, then lightweight 15's are the only way to go. You can't beat 7-10 pounds per rim that you can get in the 15 inch size(depending on your wallet size).
One day I will have FI, to compensate for the performance loss from my 17's
Old Jun 5, 2002 | 08:07 PM
Jesse H's Avatar
Actually, gearing baaaaaarely changes with the correct sized tires.
Old Jun 5, 2002 | 09:53 PM
hioctane3's Avatar
Default Re: 17's how bad (Jesse H)
It won't hurt it very much. I ran my car 3 times totally stock with some crappy Progressive 14 in. rims. All 3 times I ran a 16.3. Later that year I ran totally stock with my 17 in. TenzoR RS5's. My times were 16.5, 16.5, & 16.6. When I ran the 14's it was also 30 degrees cooler, but my tires are alot better on the 17's.
So I say get the 17's. I wish I had actually got 18's but to each his own.
Old Jun 7, 2002 | 12:41 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: 17's how bad (hioctane3)
When I put 17's on my old ITR I had better times @ the track and car felt better on the street.
Import Prelude
Apr 7, 2007 06:14 AM
dabiddan
Jan 21, 2005 02:46 AM
choNy
Jan 14, 2004 06:47 AM
Thrillhouse
Jun 30, 2002 08:27 PM
teg94
Aug 20, 2001 10:58 AM
