welding cast alluminum
Old Jun 13, 2007 | 07:57 AM
teddy_dc2's Avatar
Default welding cast alluminum
here's the problem, we forgot to take the slave cylinder off the transmission and while putting the motor back into the bay, hit and broke the slave cylinder along with part of the transmisson where the slave mounts to, everything was installed until we found out the slave cylinder just hanging there. i tried bj weld but the thing came off again after the first test drive. i do have a lincoln mig welder, i was wonder if it was possible to get the mounts welded and what type of setting? wire? also is there another route to get this thing back on? i'll try to post pix later. (runs fine, just can't shift gears. kinda have to force into gear.)
Old Jun 13, 2007 | 08:42 AM
tony1's Avatar
Default Re: welding cast alluminum (teddy_dc2)
I don't think you're going to get it done with what you have. Best bet is to replace the bellhousing or take it to someone who does aluminum fabrication for a living.
Old Jun 13, 2007 | 09:54 AM
teddy_dc2's Avatar
i was told taking off the tranny and tappin and inserting bolts from other side of tranny to mount the slave would work, but the motor is already in, i'll try to see if i can custom fab a bracket from the tranny bolt.
Old Jun 13, 2007 | 02:15 PM
BigMoose's Avatar
Default Re: (teddy_dc2)
Get some pix up, and someone may come up with an idea that may save you a lot of work...
d'sb16a2
Oct 17, 2007 04:12 PM
GSRWSU
Oct 22, 2006 11:03 AM
stRtypR25
Jan 22, 2003 07:55 PM
deviant1
Feb 28, 2002 03:03 PM
