Brand New JBL GTO601.1 II
Old Jun 13, 2007 | 07:41 AM
19t EX coupe's Avatar
Default Brand New JBL GTO601.1 II
I have a brand new in box JBL 600 watt ampiflier
Here are some pics of the actual amp:
It was purchased at a local audio shop and I have all the paperwork from the original sale. It includes a 1 year warranty from JBL that has not been registered yet.
Here are some specs:
Power Output 424 watts RMS x 1 channel at 4 ohms and ≤ 1% THD + N
580 watts RMS x 1 channel at 2 ohms, 14.4V supply
and ≤ 1% THD + N
Signal-to-Noise Ratio 72dBA (reference 1 watt into 4 ohms)
Dynamic Power 580 Watt at 4 ohms
Effective Damping Factor 6.326 at 4 ohms
Frequency Response 10Hz - 302Hz
Maximum Input Signal 5.3V
Maximum Sensitivity 210mV
Output Regulation .21dB at 4 ohms
Dimensions (H x W x D) 15-1/8" x 12-15/16" x 2-3/8"
The GTO601.1 II features a high-frequency Class D switching power supply. This topology is more efficient that traditional Class AB designs, drawing far less current from your vehicle charging system.
The GTO601.1 II features a 12dB per octave electronic crossover, allowing you to optimize bass performance based on cabin size, as well as subwoofer location and enclosure type.
RCA low-level inputs.
Full-range preamp outputs facilitate use of multiple amplifiers without the need for noisy and expensive adapters or signal splitters.
A variable bass boost circuit is provided to optimize system response.
Optional remote level bass control available.
I'm only selling because the sub I'm going to use is 2ohm DVC and that means either 1 or 4ohm load, and this amp is not 1 ohm stable. If it were I would not hesitate to run it because it puts out 580RMS at 2ohms, and it's rated at 600.
I paid $324 about a month ago, MSRP $399.95
I'm asking $300shipped OBO
-John
Old Jun 13, 2007 | 07:17 PM
Default Re: Brand New JBL GTO601.1 II (19t EX coupe)
TTT
Old Jun 16, 2007 | 11:08 PM
Make an offer, this thing is just taking up space.
-John
Old Jun 20, 2007 | 06:58 PM
Do work son
-John
Old Jun 22, 2007 | 11:29 PM
$250 Shipped and insured
-John
Teg44
May 14, 2002 06:28 PM
