FS/FT '95 Civic EX, 11.1:1 B16B, 5 lug, BC4, RM, NO RUST, **OHIO**
**INSTANT MESSAGE ME FOR SUPER DUPER GOOD PRICE ON THE CAR**
Shell is a clean title black 95 EX with black interior and NO RUST.
B16B Civic Type R Engine(50-60k)
Civic Type R LSD transmission
Place Racing motor mounts
Exedy Organic clutch disk
Exedy Pressure plate
ACT XACT 8.8lb flywheel
ARP flywheel bolts
2 layer head gasket(motor has an 11.1:1 CR)
Spoon Magnetic oil drain plug
Rocket Motorsports Generation 2 dual valve springs
Rocket Motorsports Titanium retainers
New OEM honda valve seals(200 miles ago)
Peak Performance adjustable cam gears with upgraded bolts
Peak Performance intake manifold gasket spacer
F1 SPEC Tri-Y stainless header(identical to HyTech production)
STR cam seal plug
MSD Super Conductor plug wires
Denso iridium plugs(new)
Buddy Club Spec 4 cams
Port matched Civic Type R intake manifold
JG Edelbrock 65mm throttle body
3" AEM intake
3" inlet Velocity Stack
Fluidyne aluminum radiator and fan, with Fluidyne Radiator Cap
BDL Fuel Rail(pewter in color)
AEM fuel filter(Silver)
RC 310cc injectors
ITR throttle Cable
Spoon negative battery cable end
Car will come with the red Civic Type R valve cover(cut for cam gears) and a black GSR valve cover, un cut
black Spark plug wire cover
Omni Power 2.5" test pipe
Greddy Evo2, 2.5" full Exhaust
new from Honda Distributor
Momo Monte Carlo steering wheel(350mm)
Momo Extended hub
Heel-Toe Auto pedals
JDM EG6 arm rest
JDM EG6 clock
Amber gauge cluster with green needles
Civic Type R floor mats, black
B&M single bend short shifter
Whiteline shifter bushings
Civic Type R shift ****
car may also come with a red Sparco Sprint full bucket seat and bracket
Car is partially dyno tuned on Crome by Josh Bonati at Raceline Tuning
Pherable.Net Socketed P28 ECU with Lexan cover
5 lug front and rear hubs
11.1" Front Brembo blank rotors
10.3" Rear Brembo Blank rotors
front and rear ITR calipers
Axis Metal Master front brake pads
Project Mu rear brake pads
MOTUL Dot 4 brake fluid
ITR rear trailing arm assemblies
JDM ITR rear Lower control arms
Whiteline suspension bushing kit(not complete)
Integra Type R master Cylinder
Spoon Master Cylinder resouivor cover
Omni Power front upper control arms, camber kit
Omni Power rear upper control arms
Omni Power ITR spec 12k/10k full coilovers
Currently does not have a rear sway bar on it, I was gonna order an ASR 32mm, but was figuring out if I was gonna daily drive the car or not first before I order a sway bar i'd be afraid to drive on the street with, I will include a 14mm one though if I can find it)
Wings West ABS front lip
Smoked Amber Vision replica Corners
White Civic Type R wheels(5x114.3, 15x6")
Dunlop 205/50/15 tires
Zenki Extended titanium lug nuts
Eclipse MP3/CD player Head unit
Eclipse rear 6x9's
Eclipse door speakers
tinted windows
Kenwood Amp and wiring kit(new)
(May not include the audio stuff)
for $800 extra a custom weld-in NASA legal 6pt roll cage by Chris Johnston can be included(same story as the rear sway)
I WILL NOT PART THE CAR OUT SO DON'T ASK, UNLESS my drop out sells then the rest of the shell will be parted, until that happens don't ask about anything, or even think about anything....until the drop out sells smile.gif
*ALSO* Its not some ******* hard parked show car, the car was built to be driven hard and the reason I am selling it is tonight was the first time in like a month that i've gotten to drive it
Im interning in the fall and need to get my priorities straight. SO here is your chance to have a nice daily driver with power options AND one HELL of a "weekend warrior" or track car.
only pic I have at the moment, I lost the charger to my digi cam at Nisei last year and have yet to replace it.
Modified by JadeGreenEF9 at 1:51 AM 6/18/2007
Modified by JadeGreenEF9 at 9:30 PM 6/24/2007
Modified by JadeGreenEF9 at 9:37 PM 6/24/2007
Modified by JadeGreenEF9 at 10:52 PM 6/24/2007
Modified by JadeGreenEF9 at 3:40 PM 6/26/2007
ARP flywheel bolts
STR cam seal plug
3" AEM intake
RC 310cc injectors
ITR throttle Cable
Momo Extended hub
JDM EG6 arm rest
JDM EG6 clock
Eclipse rear 6x9's
tinted windows
Im interning in the fall and need to get my priorities straight. SO here is your chance to have a nice daily driver with power options AND one HELL of a "weekend warrior" or track car.only pic I have at the moment, I lost the charger to my digi cam at Nisei last year and have yet to replace it.
Also, I thought I had this in here but I guess not..I won't take another honda in as a trade. If I wanted a fwd car i'd keep this. Im a 240 kid.
There are of course exceptions to the matter, if someone were to offer me a K'd car or RSX or S2k or something I'd think about it haha. (Remember I also have a modded clean XSi b16a swapped DA to throw in on the trade)
PLEASE, before you come and waste my time looking at the car, make sure your parents will allow you to buy it......... I had fun wasting an hour of my day yesterday for some TWENTY YEAR OLD DUDE who came down with his mom and his MOM wouldn't let him buy it because it was "too old"......
Will trade the car for a newer stock car or mildly modded car.. I have a bike to go fast on, don't need this.
