how the f-ck does the f22b2 come out?
Old Jun 4, 2002 | 10:13 PM
Accord94DX's Avatar
Default how the f-ck does the f22b2 come out?
i blew up my 3rd gear this weekend so I picked up an M2S4 tranny from a peelude Si. This means I need to swap out the f22b2 engine and trans. Can I pull both out at the same time or do I need to seperate the two? Hell, give me any tips or tricks you guys have, I will be following the helms but if there is an easier way, let me know. thanks maing(s).
Old Jun 4, 2002 | 10:17 PM
ArchAngel Sabastian's Avatar
New User
Default Re: how the f-ck does the f22b2 come out? (Accord94DX)
hacksaw
Old Jun 4, 2002 | 10:18 PM
Accord94DX's Avatar
Default Re: how the f-ck does the f22b2 come out? (Sabastian)
hacksaw
I was thinking more along the lines of oxy-acetylene torch but I guess I could expand my horizons.
Old Jun 4, 2002 | 10:20 PM
New User
mine just sounds cheaper... damnit why have i become entirely unusefull...
Old Jun 4, 2002 | 10:44 PM
FastechAccord's Avatar
Pull the axles, onbolt the motor mounts and motor drops through the bottom.
Old Jun 4, 2002 | 10:54 PM
Brandon's Avatar
Life is Suffering
Default Re: how the f-ck does the f22b2 come out? (EvoAccord)
Get a cherry picker to lift the car. I had to replace the tranny in a 90 EX which is a pain in the *** if any of you have had to do it. Unbolt the tranny from everything but the engine, loosen the engine mounts, remove the tranny bolts from the engine, and remove the axles. Lift the car up a few feet VERY slowly. set the tranny down carefully and then move the oher tranny to the same place and do everything in reverse, with the axle replacement last. Also, do not use the intermediate shaft from a Prelude or else you will find two males cannot connect. Other than that, an original Honda service manual helps, but everything is pretty easy.
Old Jun 4, 2002 | 11:03 PM
Accord94DX's Avatar
Both the engine and transmission are being taken out for the h23a1 and m2s4. i felt a rephrase is necessary.
Old Jun 4, 2002 | 11:10 PM
Brandon's Avatar
Life is Suffering
Same thing, just disconnect everything from the engine and tranny and remove the engine mounts. The cherry picker is a very, very imortant part of it all. Also, I have a factory Honda service manual that I borrowed from a friend which may help. I can email you with any help you may need, since the Honda manual has everything you will need. And then some.
[Modified by vtec2k2, 3:14 AM 6/5/2002]
Old Jun 5, 2002 | 04:07 AM
Kazmans94cord's Avatar
man brian you must be like a kid in a candy store....your already swapping it?
Old Jun 5, 2002 | 05:53 AM
4doorH22's Avatar
Keep the engine and tranny together when you take them out of the car. If you separate them to put in a new clutch or something, put the tranny back on to the motor before you put it into your car. It's much easier to do it once.
Old Jun 5, 2002 | 05:59 AM
Stew Pidasso's Avatar
Default Re: how the f-ck does the f22b2 come out? (vtec2k2)
Will the engine and tranny ONLY come out from the bottom or is it just easier that way?
Old Jun 5, 2002 | 09:10 AM
H23 Power's Avatar
Default Re: how the f-ck does the f22b2 come out? (Nitz5785)
i pulled mine out the top...its not that hard...
but like its been said, it is a bitch to change the tranny with the engine in the car...so pull the whole assembly, then install the whole new assembly
Old Jun 5, 2002 | 10:51 AM
KGAccord's Avatar
Default Re: how the f-ck does the f22b2 come out? (01GSR)
A helms or honda shop manual would be a good start.
Old Jun 5, 2002 | 01:48 PM
Nick M's Avatar
Default Re: how the f-ck does the f22b2 come out? (KGAccord)
My H22 is sitting on a palette at work (Honda) most likely gonna start on the 17th. Good luck Brian.
Old Jun 12, 2002 | 12:40 AM
Accord94DX's Avatar
Default Re: how the f-ck does the f22b2 come out? (HondaSport)
BUMP..........anyone else have an idea?
Old Jun 12, 2002 | 01:33 AM
matt_sb2000's Avatar
Well I know from experience that you can pull that motor out the top of the car. I would suggest one of those ghey engine leveler things though. If you can't get it out with out mangaling the pulley take it off and you should have no problem. As for putting it back in the car, deffinately leave the engine and trans togather. If possable put the harness on it while it is out of the car.... trust me on that.
Good luck
Matt
Old Jun 12, 2002 | 02:28 AM
CD8's Avatar
CD8
Default Re: how the f-ck does the f22b2 come out? (matt_sb2000)
where would you connect the cherry picker to if you lifted the car? i know there is a hook for you to chain the engine hoist (isnt that the same as a cherry picker?) to the engine, so it would be logical to lift the engine from the car.
where can i buy a honda service manual? dealer? probably pretty $$
[Modified by exaccord, 3:39 AM 6/12/2002]
Old Jun 12, 2002 | 04:04 PM
sloaccord's Avatar
New User
Default Re: how the f-ck does the f22b2 come out? (exaccord)
step one: open hood
step two: throw grenade in engine bay
step three: close hood
Old Jun 12, 2002 | 04:08 PM
Martaigne's Avatar
I used a cherry picker to pull my engine out of the top of the bay, make sure everything (and I do mean everything) is disconnected. I forgot the oxygen sensor line and tore it in half.
Old Jun 12, 2002 | 08:10 PM
Accord94DX's Avatar
get a helms manual from http://www.helminc.com, they should have a phone #
Old Jun 13, 2002 | 01:08 PM
CD8's Avatar
CD8
daym! $64! thats the right one right? i want to make sure its right before i buy it...
Old Jun 13, 2002 | 02:57 PM
4doorH22's Avatar
OMG you do not have a Helms yet? Shame shame
Old Jun 13, 2002 | 02:59 PM
CD8's Avatar
CD8
Default Re: how the f-ck does the f22b2 come out? (4doorH22)
i have a chilton
i need to add that to my list
Old Jun 13, 2002 | 03:05 PM
Martaigne's Avatar
I don't either. Believe it or not, a Haynes got me this far.
Old Jun 13, 2002 | 03:14 PM
4doorH22's Avatar
Default Re: how the f-ck does the f22b2 come out? (martaigne)
Well with resources like H-T one doesn't really need a manual at all... the Helms is just something everyone should have. I keep it in the bathroom so I can read up on vacuum lines while dropping a deuce.
