high idle
just bought a 90 si b16 it hd an msn ignition and coil, cel #9 runs like crap absolutely no power,put oe dizzy off of my other b16 si,(which is my daily driver) started to idle at 3k an blowing alot of smoke. did not smoke at all before the dizzy swap??????
hmm the cel is cyl1 position sensor that usually points to the dizzy but if u replaced it already then... perhaps a problm in the harness. and mebbe adjust the throttle cable see if it idles down
