blending with spray paint
i hope you just fixed a spot on your bicycle and are painting it.
it wont work becuase when you blend there is ussually a blending adative in the paint.
dc5r2002 is right. Blending will be near impossible because the paint will not flow flat. The additive used is basically a slow reacting activator. To let the material flow flat after being sprayed.
