Squealing noise from passenger wheel...searched!!! Should i swap whole Knucle and Controll arm??
ok i get this damn squealing from my front passenger wheel, i only get it above 20 mph and it stays the same or gets louder as i accelerate.
I've sprayed all my bushings down low and still same thing.
It could be my wheel bearing but i think that sounds more like rubbing metal,
this sounds like rubber on metal.
Could i swap out whoe knuckle from a another eg??
how should i?
and whats easier
kuncle or whole controll arm?
how should i?
and whats easier
From: everything for everyone, and nothing for ourselves
Wheel bearing. Pull the spindle out and take it anywhere with a machine press. A new bearing cost me $45 on ebay (good deal) but, i think, they retail a $60? hopefully the hub isn't fuct, if it is it should be less expensive to buy the spindle complete from the junkyard.
Some times the metal backing plate from your whole knuckle gets bent and squeels..
After I had my wheel bearings done,
the guy accidently bent the backing a littleand I swore up and down he fucked some **** up...
Id check the backingplate 1st... since it would be an easy/free fix
