dohc zc rods+slugs into d16a6????
Old Jun 12, 2007 | 03:56 PM
hondasaurusrex's Avatar
Default dohc zc rods+slugs into d16a6????
spun a rod bearing and bent a rod in my D16a6...and ive got the rotating assembly from my dohc zc (zc's block is trashed) and i wanna throw it in my a6 so i dont have to buy a new rod.....how greatly will this effect my compression ratio? will i need to worry about having a piston hit a valve?
Old Jun 12, 2007 | 04:01 PM
jlicrx's Avatar
Default Re: dohc zc rods+slugs into d16a6???? (hondasaurusrex)
compression ratio will be 10.78:1 and no, you don't need to worry about piston hitting the valves, unless you have some really, really radical camshaft
Old Jun 12, 2007 | 07:01 PM
Default Re: dohc zc rods+slugs into d16a6???? (jlicrx)
niiiiice.....so this would be safe to run daily on premium right?? im also going to have my stock head milled .030" because it has popped a few gaskets before and i want a fresh mating surface
zookr
Jan 29, 2007 02:08 PM
NathanMorris
Aug 28, 2006 09:14 AM
ek_99_SiR
Mar 1, 2004 04:28 PM
redzcstandardhatch
14
Apr 30, 2003 11:42 AM
turbozc2001
Apr 3, 2002 04:02 AM
