Fuel pump removal question? Jumper wire, whys it required
Old Jun 12, 2007 | 03:41 PM
djnikko's Avatar
Default Fuel pump removal question? Jumper wire, whys it required
It says in the workshop manual to disconnect the connector from the main relay at the left hand side of the cowl and and to bridge the blk/yellow and yellow/blk wires together. I did this removal about a year back and did not do this when installing a walbro. Does anyone know what this procedure does?
Thanks
Old Jun 12, 2007 | 03:45 PM
djnikko's Avatar
Default Re: Fuel pump removal question? Jumper wire, whys it required (djnikko)
Sorry my bad. That procedure is for "testing" the fuel pump. I guess it stops the fuel igniting or something along those lines.
Old Jun 12, 2007 | 03:53 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">It says in the workshop manual to disconnect the connector from the main relay at the left hand side of the cowl and and to bridge the blk/yellow and yellow/blk wires together. I did this removal about a year back and did not do this when installing a walbro. Does anyone know what this procedure does?
Thanks </TD></TR></TABLE>the part about the jumper wire is for the testing of the fuel pump, not replacement - when you turn the ignition on, the fuel pump should run for about 2 seconds and then shut off - if the pump isn't coming on, what you are doing by jumping the wires is bypassing the Main Relay to see if you are getting power to the fuel pump - if the pump is running with the jumper connected, then you know it is not the pump and could be the Main Relay - if it still isn't running, you probe the wires at the pump to see if you have power - if you have power, then pump is bad
girlcrx
Mar 9, 2014 06:04 PM
fusion645
Audio / Security / Video
May 9, 2011 04:48 PM
CivicPride97
May 20, 2008 05:21 PM
Eresuncabron
Nov 27, 2003 08:09 AM
