Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
ECU Reset
Old Jun 12, 2007 | 02:32 PM
ultimatehonda's Avatar
Default ECU Reset
How do you reset the ecu in a 07 SI?
Old Jun 12, 2007 | 02:37 PM
FBPSidan's Avatar
Default Re: ECU Reset (ultimatehonda)
make sure car is off...Take both battery terminals off.... touch em together... reconnect and let idle for 2 cycles
Old Jun 12, 2007 | 02:39 PM
pd0019's Avatar
disconnect battery and let it sit for ~20 min...then reconnect and let the car idle for a little bit
Old Jun 12, 2007 | 03:42 PM
Default Re: ECU Reset (pd0019)
Ok I did that. The reason I wanted to reset it was because im in "limp" mode and the car will not rev past 3k rpms. Also the VSA light is on and wont come off when I push the button. Will the VSA have anything to do with the car being in limp mode? Has this happened to anyone before? Any help will be appriciated.
Thanks
Old Jun 12, 2007 | 03:56 PM
FBPSidan's Avatar
Have you checked your oil level? If its low it will not allow vtec and could also be the problem of the light (as per my buddy who was a tech for years)
Old Jun 12, 2007 | 04:08 PM
exhaust_note's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">Ok I did that. The reason I wanted to reset it was because im in "limp" mode and the car will not rev past 3k rpms. Also the VSA light is on and wont come off when I push the button. Will the VSA have anything to do with the car being in limp mode? Has this happened to anyone before? Any help will be appriciated.
Thanks</TD></TR></TABLE>
yea i ate through my abs sensor wire. i also had the light come on and stay on when i spun out. but i just turned the car off and then back on and it was fine.
b0yg0tskills
Honda Civic (2001 - 2005)
11
Nov 26, 2006 07:18 PM
ap1_s2k
Honda S2000
14
May 9, 2006 11:53 AM
moecivic
Dec 19, 2004 11:28 AM
pRosmAt3c
Apr 20, 2003 02:21 PM
FroggyR
Mar 10, 2002 05:36 PM
